Prometheus
| 2/stable | 287 | 16 Mar 2026 | |
| 2/candidate | 287 | 13 Mar 2026 | |
| 2/beta | 287 | 13 Mar 2026 | |
| 2/edge | 287 | 13 Mar 2026 | |
| dev/edge | 291 | 16 Apr 2026 | |
| 1/stable | 247 | 14 May 2025 | |
| 1/candidate | 247 | 14 May 2025 | |
| 1/beta | 247 | 14 May 2025 | |
| 1/edge | 247 | 14 May 2025 |
juju deploy prometheus-k8s --channel dev/edge
Mimir provides a scalable and long-term storage solution for metrics, making it a suitable alternative for Prometheus. This How-to will highlight validation steps to provide confidence to the operator that the migration from Prometheus to Mimir is successful without data loss.
Deploy Mimir
Deploy Mimir alongside Prometheus. Then relate Mimir to all the same applications and endpoints that Prometheus has.
Validation
Now we can validate whether Mimir is receiving the same data as Prometheus.
These validations are not exhaustive. More validations can be added to boost migration confidence
Validate metric name outputs
juju ssh prometheus/0 curl -g 'http://localhost:9090/api/v1/label/__name__/values' | jq -r ".data[]" | sort -u > prom-metric.txtjuju ssh mimir/0 curl -g 'http://localhost:8080/prometheus/api/v1/label/__name__/values' | jq -r ".data[]" | sort -u > mimir-metric-names.txt
Confirm that the same metrics in Prometheus are in Mimir by inspecting diff:
diff -y prom-metrics.txt mimir-metrics.txt
Other validations
| Validation | Prometheus | Mimir |
| labels | api/v1/labels | /prometheus/api/v1/labels |
| app names | api/v1/label/juju_application/values | prometheus/api/v1/label/juju_application/values |
| alerts | api/v1/rules | prometheus/api/v1/rules |
For alerts, the API response will result in a large JSON output and we can modify the jq to jq -r ".data[][].name" to aggregate the alert names for validation.
Remove Prometheus
Once the validations are complete, check the config value for metrics_retention_time with the command:
juju config prometheus metrics_retention_time
This is how long samples are retained in the storage (Units Supported: y, w, d, h, m, s). Before deleting Prometheus, this much time must pass prior to removing the Prometheus application to ensure that no data is lost.
Once Prometheus is removed, you are done and you can enjoy a modernized deployment.
