Prometheus
| 3.11/stable | 309 | 06 Jul 2026 | |
| 3.11/candidate | 327 | 26 Sep 2026 | |
| 3.11/beta | 327 | 26 Sep 2026 | |
| 3.11/edge | 327 | 25 Sep 2026 | |
| dev/edge | 331 | 30 Sep 2026 | |
| 3.14/candidate | 332 | 02 Oct 2026 | |
| 3.14/beta | 332 | 02 Oct 2026 | |
| 3.14/edge | 332 | 01 Oct 2026 | |
| 2/stable | 301 | 25 Jun 2026 | |
| 2/candidate | 301 | 18 Jun 2026 | |
| 2/beta | 301 | 18 Jun 2026 | |
| 2/edge | 301 | 17 Jun 2026 | |
| 1/stable | 247 | 14 May 2025 | |
| 1/candidate | 247 | 14 May 2025 | |
| 1/beta | 247 | 14 May 2025 | |
| 1/edge | 247 | 14 May 2025 |
juju deploy prometheus-k8s --channel 3.11/stable
Prometheus for Kubernetes clusters
Prometheus K8s is a Juju charm that deploys and manages Prometheus on Kubernetes, providing a monitoring and alerting solution based on a time-series database. It is a core component of COS Lite, the lightweight version of the Canonical Observability Stack (COS): https://documentation.ubuntu.com/observability
Related charms automatically register their metrics endpoints and alert rules through Juju relations, and collected metrics can be visualized in Grafana and used to trigger alerts via Alertmanager.
Key features:
- Automatic metrics scraping and alert rule registration via Juju relations with any charm that supports the prometheus_scrape interface.
- Prometheus remote write endpoint for receiving metrics from agents such as OpenTelemetry Collector.
- Seamless integration with Grafana, Alertmanager, and other charms in the COS ecosystem through Juju relations.
- Built-in Grafana dashboards and Prometheus alert rules for self-monitoring.
- Configurable metrics retention by time and storage size, with WAL compression support.
- Per-unit ingress support for cross-model access through reverse proxies such as Traefik.
- TLS support via the certificates relation.
- Distributed tracing support via integration with Tempo.
- Persistent storage for the time-series database across container restarts.
- Configurable Kubernetes resource limits for CPU and memory.
