Prometheus
- Canonical Observability
latest/stable | 234 | 15 Apr 2025 | |
latest/candidate | 237 | 15 Apr 2025 | |
latest/beta | 241 | 15 Apr 2025 | |
latest/edge | 245 | 17 Apr 2025 | |
latest/edge | 244 | 17 Apr 2025 | |
1.0/stable | 159 | 16 Feb 2024 | |
1.0/candidate | 159 | 12 Dec 2023 | |
1.0/beta | 159 | 12 Dec 2023 | |
1.0/edge | 159 | 12 Dec 2023 |
juju deploy prometheus-k8s --channel edge
These guides accompany you through the complete prometheus-k8s-operator
operations lifecycle.
Integrating
- Integrate with external (non-charmed) workloads
- Modify alert rules for a certain deployment
- Integrating
