postgresql-k8s
Charmed PostgreSQL K8s
latest/stable 20 20 Sep 2022
Ubuntu 20.04
14/stable 495 18 Feb 2025
14/stable 494 18 Feb 2025
14/candidate 495 11 Feb 2025
14/candidate 494 11 Feb 2025
14/beta 495 06 Feb 2025
14/beta 494 06 Feb 2025
14/edge 557 Today
14/edge 556 Today
16/beta 525 19 Mar 2025
Ubuntu 24.04
16/beta 524 19 Mar 2025
Ubuntu 24.04
16/edge 553 02 Apr 2025
Ubuntu 24.04
16/edge 552 02 Apr 2025
Ubuntu 24.04
Charmed PostgreSQL K8s Tutorial > 5. Manage passwords
Manage passwords
When we accessed PostgreSQL earlier in this tutorial, we needed to use a password manually. Passwords help to secure our database and are essential for security. Over time, it is a good practice to change the password frequently.
In this section, we will go through setting and changing the password for the admin user.
Retrieve the operator password
The operator’s password can be retrieved by running the get-password action on the Charmed PostgreSQL K8s application:
juju run postgresql-k8s/leader get-password
Running the command above should output:
unit-postgresql-k8s-0:
  UnitId: postgresql-k8s/0
  results:
    password: SYhCduijXTAfg9mU
  status: completed
  timing:
    completed: 2023-03-20 11:10:33 +0000 UTC
    enqueued: 2023-03-20 11:10:32 +0000 UTC
    started: 2023-03-20 11:10:33 +0000 UTC
Rotate the operator password
You can change the operator’s password to a new random password by entering:
juju run postgresql-k8s/leader set-password
  results:
    password: 7CYrRiBrC4du3ToX
  status: completed
  timing:
    completed: 2023-03-20 11:10:47 +0000 UTC
    enqueued: 2023-03-20 11:10:46 +0000 UTC
    started: 2023-03-20 11:10:47 +0000 UTC
The status: completed element in the output above indicates that the password has been successfully updated. The new password should be different from the previous password.
Set a new password…
You can set a specific password for any user by running the set-password juju action on the leader unit.
…for the operator user
To set a manual password for the operator/admin user, run the following command:
juju run postgresql-k8s/leader set-password password=my-password
where my-password is your password of choice.
Example output:
  results:
    password: my-password
  status: completed
  timing:
    completed: 2023-03-20 11:11:06 +0000 UTC
    enqueued: 2023-03-20 11:11:02 +0000 UTC
    started: 2023-03-20 11:11:05 +0000 UTC
…for another user
To set a manual password for another user, run the following command:
juju run postgresql-k8s/leader set-password username=my-user password=my-password
Read more about internal operator users here.
Next step: 6. Integrate with other applications
Help improve this document in the forum (guidelines). Last updated 11 months ago.
