postgresql-k8s
Charmed PostgreSQL K8s
latest/stable 20 20 Sep 2022
Ubuntu 20.04
14/stable 495 18 Feb 2025
14/stable 494 18 Feb 2025
14/candidate 495 11 Feb 2025
14/candidate 494 11 Feb 2025
14/beta 495 06 Feb 2025
14/beta 494 06 Feb 2025
14/edge 555 04 Apr 2025
14/edge 554 04 Apr 2025
16/beta 525 19 Mar 2025
Ubuntu 24.04
16/beta 524 19 Mar 2025
Ubuntu 24.04
16/edge 553 02 Apr 2025
Ubuntu 24.04
16/edge 552 02 Apr 2025
Ubuntu 24.04
Charmed PostgreSQL K8s Tutorial > 7. Enable TLS
Enable encryption with TLS
Transport Layer Security (TLS) is a protocol used to encrypt data exchanged between two applications. Essentially, it secures data transmitted over a network.
Typically, enabling TLS internally within a highly available database or between a highly available database and client/server applications, requires domain-specific knowledge and a high level of expertise. This has all been encoded into Charmed PostgreSQL K8s. This means (re-)configuring TLS on Charmed PostgreSQL K8s is readily available and requires minimal effort on your end.
Again, integrations come in handy here as TLS is enabled by relating Charmed PostgreSQL K8s to the Self Signed Certificates Charm. This charm centralises TLS certificate management consistently and handles operations like providing, requesting, and renewing TLS certificates.
In this part of the tutorial, you will learn how to enable security in your PostgreSQL deployment using TLS encryption.
Self-signed certificates are not recommended for a production environment.
Check this guide for an overview of the TLS certificates charms available.
Enable TLS
To enable TLS, you must deploy a charm that provides TLS certificates and integrate it with PostgreSQL.
Deploy TLS charm
Before enabling TLS on Charmed PostgreSQL K8s, we must deploy the self-signed-certificates charm:
juju deploy self-signed-certificates --config ca-common-name="Tutorial CA"
Wait until the self-signed-certificates is up and active by using juju status --watch 1s to monitor the deployment status
tutorial  charm-dev   microk8s/localhost  3.1.7    unsupported  12:18:05+01:00
App                        Version  Status   Scale  Charm                      Channel    Rev  Address         Exposed  Message
postgresql-k8s                      active       2  postgresql-k8s             14/stable  56   10.152.183.167  no
self-signed-certificates            active       1  self-signed-certificates   stable     72   10.152.183.138  no
Unit                          Workload    Agent  Address       Ports  Message
postgresql-k8s/0*             active      idle   10.1.188.206         Primary
postgresql-k8s/1              active      idle   10.1.188.209
self-signed-certificates/0*   active      idle   10.1.188.212
Integrate with PostgreSQL
To enable TLS on Charmed PostgreSQL K8s, integrate the two applications:
juju integrate postgresql-k8s:certificates self-signed-certificates:certificates
Check the TLS certificate in use
Use openssl to connect to the PostgreSQL and check the TLS certificate in use:
> openssl s_client -starttls postgres -connect 10.1.188.206:5432 | grep Issuer
depth=1 C = US, CN = Tutorial CA
verify error:num=19:self-signed certificate in certificate chain
Congratulations! PostgreSQL is now using TLS certificate generated by the external application self-signed-certificates.
Disable TLS
To disable the external TLS, remove the integration:
juju remove-relation postgresql-k8s:certificates self-signed-certificates:certificates
If you once again check the TLS certificates in use via the OpenSSL client, you will see something similar to the output below:
no peer certificate available
No client certificate CA names sent
The Charmed PostgreSQL K8s application is not using TLS anymore.
Next step: 8. Clean up environment
