postgresql-k8s
Charmed PostgreSQL K8s
latest/stable 20 20 Sep 2022
Ubuntu 20.04
14/stable 495 18 Feb 2025
14/stable 494 18 Feb 2025
14/candidate 495 11 Feb 2025
14/candidate 494 11 Feb 2025
14/beta 495 06 Feb 2025
14/beta 494 06 Feb 2025
14/edge 555 04 Apr 2025
14/edge 554 04 Apr 2025
16/beta 525 19 Mar 2025
Ubuntu 24.04
16/beta 524 19 Mar 2025
Ubuntu 24.04
16/edge 553 02 Apr 2025
Ubuntu 24.04
16/edge 552 02 Apr 2025
Ubuntu 24.04
Manage backup retention
Charmed PostgreSQL K8s backups can be managed via a retention policy. This retention can be set by the user in the form of a configuration parameter in the charm s3-integrator via the config option experimental-delete-older-than-days.
This guide will teach you how to set this configuration and how it works in managing existing backups.
Note: This is an EXPERIMENTAL parameter, use it with caution.
Configure S3-integrator charm
If not done already, deploy and run the charm:
juju deploy s3-integrator
juju run s3-integrator/leader sync-s3-credentials access-key=<access-key-here> secret-key=<secret-key-here>
Then, use juju config to add the desired retention time in days:
juju config s3-integrator experimental-delete-older-than-days=<number-of-days>
To pass these configurations to a Charmed PostgreSQL K8s application, integrate the two applications:
juju integrate s3-integrator postgresql-k8s
If at any moment it is desired to remove this option, the user can erase this configuration from the charm:
juju config s3-integrator --reset experimental-delete-older-than-days
Note: This configuration will be enforced in every Charmed PostgreSQL application related to the configured S3-integrator charm
Note: The retention is not enforced automatically once a backup is older than the set amount of days: Backups older than the set retention time will only get expired only once a newer backup is created.
This behavior avoids complete backup deletion if there has been no newer backups created in the charm.
The s3-integrator charm accepts many configurations - enter whichever are necessary for your S3 storage.
Help improve this document in the forum (guidelines). Last updated 10 months ago.
