postgresql-k8s
Charmed PostgreSQL K8s
latest/stable 20 20 Sep 2022
Ubuntu 20.04
14/stable 495 18 Feb 2025
14/stable 494 18 Feb 2025
14/candidate 495 11 Feb 2025
14/candidate 494 11 Feb 2025
14/beta 495 06 Feb 2025
14/beta 494 06 Feb 2025
14/edge 555 04 Apr 2025
14/edge 554 04 Apr 2025
16/beta 525 19 Mar 2025
Ubuntu 24.04
16/beta 524 19 Mar 2025
Ubuntu 24.04
16/edge 553 02 Apr 2025
Ubuntu 24.04
16/edge 552 02 Apr 2025
Ubuntu 24.04
How to enable LDAP authentication
Disclaimer: In this guide, we use self-signed certificates provided by the self-signed-certificates operator.
This is not recommended for a production environment.
For production environments, check the collection of Charmhub operators that implement the tls-certificate interface, and choose the most suitable for your use-case.
Deploy an LDAP server
Deploy the GLAuth charm:
juju deploy postgresql-k8s --channel 14/stable --trust postgresql-k8s-glauth
juju deploy glauth-k8s --channel edge --trust
Integrate (formerly known as “relate”) the three applications:
juju integrate glauth-k8s self-signed-certificates
juju integrate glauth-k8s postgresql-k8s-glauth
Deploy the GLAuth-utils charm, in order to manage LDAP users:
juju deploy glauth-utils --channel edge --trust
Integrate (formerly known as “relate”) the two applications:
juju integrate glauth-k8s glauth-utils
Enable LDAP
To have LDAP authentication enabled, relate the PostgreSQL charm with the GLAuth charm:
juju integrate postgresql-k8s:ldap glauth-k8s:ldap
juju integrate postgresql-k8s:receive-ca-cert glauth-k8s:send-ca-cert
Map LDAP users to PostgreSQL
To have LDAP users available in PostgreSQL, provide a comma separated list of LDAP groups to already created PostgreSQL authorization groups. To create those groups before hand, refer to the Data Integrator charm page.
juju config postgresql-k8s ldap_map="<ldap_group>=<psql_group>"
Disable LDAP
You can disable LDAP by removing the following relations:
juju remove-relation postgresql-k8s:receive-ca-cert glauth-k8s:send-ca-cert
juju remove-relation postgresql-k8s:ldap glauth-k8s:ldap
