postgresql-k8s
Charmed PostgreSQL K8s
latest/stable 20 20 Sep 2022
Ubuntu 20.04
14/stable 495 18 Feb 2025
14/stable 494 18 Feb 2025
14/candidate 495 11 Feb 2025
14/candidate 494 11 Feb 2025
14/beta 495 06 Feb 2025
14/beta 494 06 Feb 2025
14/edge 555 04 Apr 2025
14/edge 554 04 Apr 2025
16/beta 525 19 Mar 2025
Ubuntu 24.04
16/beta 524 19 Mar 2025
Ubuntu 24.04
16/edge 553 02 Apr 2025
Ubuntu 24.04
16/edge 552 02 Apr 2025
Ubuntu 24.04
Cryptography
This document describes the cryptography used by Charmed PostgreSQL K8s.
Resource checksums
Charmed PostgreSQL K8s and Charmed PgBouncer K8s operators use pinned versions of the respective images (Charmed PostgreSQL rock and PgBouncer rock) to provide reproducible and secure environments.
The rocks are OCI images derived from the respective snaps. Snaps package their workload along with the necessary dependencies and utilities required for the operators’ lifecycle. For more details, see the snaps content in the snapcraft.yaml file for PostgreSQL and PgBouncer.
Every artifact bundled into a snap is verified against its MD5, SHA256, or SHA512 checksum after download. The installation of certified snap into the rock is ensured by snap primitives that verify their squashfs filesystems images GPG signature. For more information on the snap verification process, refer to the snapcraft.io documentation.
Sources verification
PostgreSQL and its extra components are built by Canonical from upstream source codes on Launchpad. PostgreSQL and PgBouncer are built as deb packages, other components - as PPAs.
Charmed PostgreSQL K8s and Charmed PgBouncer K8s charms, snaps, and rocks are published and released programmatically using release pipelines implemented via GitHub Actions in their respective repositories.
All repositories in GitHub are set up with branch protection rules, requiring:
  • new commits to be merged to main branches via pull request with at least 2 approvals from repository maintainers
  • new commits to be signed (e.g. using GPG keys)
  • developers to sign the Canonical Contributor License Agreement (CLA)
Encryption
Charmed PostgreSQL K8s can be used to deploy a secure PostgreSQL cluster on K8s that provides encryption-in-transit capabilities out of the box for:
  • Cluster internal communications
  • PgBouncer connections
  • External clients connections
To set up a secure connection Charmed PostgreSQL K8s and Charmed PgBouncer K8s need to be integrated with TLS Certificate Provider charms, e.g. self-signed-certificates operator. Certificate Signing Requests (CSRs) are generated for every unit using the tls_certificates_interface library that uses the cryptography Python library to create X.509 compatible certificates. The CSR is signed by the TLS Certificate Provider, returned to the units, and stored in Juju secret. The relation also provides the CA certificate, which is loaded into Juju secret.
Encryption at rest is currently not supported, although it can be provided by the substrate (cloud or on-premises).
Authentication
In Charmed PostgreSQL, authentication layers can be enabled for:
  1. PgBouncer authentication to PostgreSQL
  2. PostgreSQL cluster authentication
  3. Clients authentication to PostgreSQL
Authentication of PgBouncer to PostgreSQL is based on the password-based scram-sha-256 authentication method. See the PostgreSQL official documentation for more details.
Credentials are exchanged via Juju secrets.
Authentication among members of a PostgreSQL cluster is based on the password-based scram-sha-256 authentication method.
An internal user is used for this authentication with its hashed password stored in a system metadata database. These credentials are also stored as a plain text file on the disk of each unit for the Patroni HA service.
Authentication of clients to PostgreSQL is based on the password-based scram-sha-256 authentication method. See the PostgreSQL official documentation for more details.
