postgresql-k8s
Charmed PostgreSQL K8s
latest/stable 20 20 Sep 2022
Ubuntu 20.04
14/stable 495 18 Feb 2025
14/stable 494 18 Feb 2025
14/candidate 495 11 Feb 2025
14/candidate 494 11 Feb 2025
14/beta 495 06 Feb 2025
14/beta 494 06 Feb 2025
14/edge 557 Today
14/edge 556 Today
16/beta 525 19 Mar 2025
Ubuntu 24.04
16/beta 524 19 Mar 2025
Ubuntu 24.04
16/edge 553 02 Apr 2025
Ubuntu 24.04
16/edge 552 02 Apr 2025
Ubuntu 24.04
Connection pooling
Connection pooling is a strategy to reduce the amount of active connections and the costs of reopening connections. It requires maintaining a set of persistently opened connections, called a pool, that can be reused by clients.
Since PostgreSQL K8s spawns separate processes for client connections, it can be beneficial in some use cases to maintain a client side connection pool rather than increase the database connection limits and resource consumption.
A way to achieve this with Charmed PostgreSQL K8s is by integrating with the PgBouncer K8s charm.
Increasing maximum allowed connections
If using PgBouncer is not enough to handle the connections load of your application, you can increase the amount of connections that PostgreSQL can open via the experimental_max_connections config parameter.
Disclaimer: Each connection opened by PostgreSQL spawns a new process, which is resource-intensive. Use this option as a last resort.
Contact us for more guidance about your use-case.
