OpenSearch
- Canonical
2/stable | 168 | 24 Sep 2024 | |
2/candidate | 168 | 24 Sep 2024 | |
2/beta | 168 | 24 Sep 2024 | |
2/edge | 191 | Today |
Charmed OpenSearch Tutorial
This tutorial is designed to help you learn how to deploy Charmed OpenSearch and become familiar with its available operations.
To get started right away, go to Step 1. Set up the environment.
While this tutorial intends to guide you as you deploy Charmed OpenSearch for the first time, it will be most beneficial if:
- You have some experience using a Linux-based CLI
- You are familiar with OpenSearch concepts such as indices and users.
- To learn more, see the official OpenSearch Documentation
- Your computer fulfils the minimum system requirements
Tutorial contents
The following topics are covered:
Step | Details |
1. Set up the environment | Set up a cloud environment for you deployment with LXD |
2. Deploy OpenSearch | Learn how to deploy OpenSearch with Juju |
3. Enable TLS encryption | Enable security in your deployment by integrating with a TLS certificates operator |
4. Integrate with a client application | Learn how to a client app with OpenSearch and manage users |
5. Manage passwords | Learn about password management and rotation |
6. Scale horizontally | Scale your application by adding or removing juju units |
7. Clean up the environment | Remove your OpenSearch deployment and juju to free your machine’s resources |
Get started: Step 1. Set up the environment
