OpenSearch
- Canonical
2/stable | 168 | 24 Sep 2024 | |
2/candidate | 168 | 24 Sep 2024 | |
2/beta | 168 | 24 Sep 2024 | |
2/edge | 219 | 07 Apr 2025 | |
2/edge | 218 | 07 Apr 2025 |
Charmed OpenSearch Tutorial > 2. Deploy OpenSearch
Deploy OpenSearch
Charmed OpenSearch supports performance profile. It is recommended in a single host deployment with LXD to use the testing
profile, which will only consume 1G RAM per container.
To deploy Charmed OpenSearch, run the following command:
juju deploy opensearch -n 3 --config profile=testing
The
-n
flag is optional and specifies the number of units to deploy. In this case, we are deploying three units of Charmed OpenSearch. We recommend deploying at least three units for high availability.
This command will fetch the charm from Charmhub and deploy 3 units to the LXD cloud. This process can take several minutes depending on your machine.
You can track the progress by running:
juju status --watch 1s
This command is useful for checking the status of your Juju model, including the applications and machines it hosts. Helpful information it displays includes IP addresses, ports, state, etc. The output of this command updates once every other second.
When the application is ready, juju status
will show something similar to the sample output below:
tutorial opensearch-demo localhost/localhost 3.5.3 unsupported 12:36:56Z
opensearch blocked 3 opensearch 2/stable 168 no Missing TLS relation with this cluster.
opensearch/0* blocked idle 0 10.95.38.94 Missing TLS relation with this cluster.
opensearch/1 blocked executing 1 10.95.38.139 Missing TLS relation with this cluster.
opensearch/2 blocked idle 2 10.95.38.212 Missing TLS relation with this cluster.
0 started 10.95.38.94 juju-be3883-0 ubuntu@22.04 Running
1 started 10.95.38.139 juju-be3883-1 ubuntu@22.04 Running
2 started 10.95.38.212 juju-be3883-2 ubuntu@22.04 Running
To exit the juju status
screen, enter Ctrl + C
The status message Waiting for TLS to be fully configured...
is displayed because Charmed OpenSearch requires TLS to be configured before use, to ensure data is encrypted in transit for the HTTP and Transport layers. We will do this in the next step.
If you see the following status message:
vm.swappiness should be 0 - net.ipv4.tcp_retries2 should be 5
you need to set the correct kernel parameters to continue.
Next step: 3. Enable TLS
