opensearch
OpenSearch
2/stable 168 24 Sep 2024
2/candidate 168 24 Sep 2024
2/beta 168 24 Sep 2024
2/edge 219 Yesterday
Ubuntu 24.04 Ubuntu 22.04
2/edge 218 Yesterday
All commands are written for juju > v3.1.7+
How to create a backup
This guide contains recommended steps and useful commands for creating and managing backups to ensure smooth restores.
  • A cluster with at least three nodes deployed
  • Access to an S3-compatible storage
  • Configured settings for the S3-compatible storage
Save your current cluster credentials
For security reasons, charm credentials are not stored inside backups. So, if you plan to restore to a backup at any point in the future, you will need the new user password as well as certificates/keys for your existing cluster.
You can retrieve the credentials of the admin user with the following command:
juju run opensearch/leader get-password
Running operation 141 with 1 task
  - task 142 on unit-opensearch-0
Waiting for task 142...
ca-chain: |-
  -----BEGIN CERTIFICATE-----
  -----END CERTIFICATE-----
password: <pass>
username: admin
Create a backup
Once you have a three-node cluster with configurations set for S3 storage, check that Charmed OpenSearch is active and idle with juju status.
Once Charmed OpenSearch is active and idle, you can create your first backup with the create-backup command:
juju run opensearch/leader create-backup
Running operation 333 with 1 task
  - task 334 on unit-opensearch-0
Waiting for task 334...
backup-id: "2024-04-25T21:16:26Z"
status: Backup is running.
List backups
You can list your available, failed, and in progress backups by running the list-backups command:
juju run opensearch/leader list-backups
Running operation 335 with 1 task
  - task 336 on unit-opensearch-0
Waiting for task 336...
backups: |2-
   backup-id           | backup-status
  2024-04-25T21:09:38Z | success
  2024-04-25T21:16:26Z | success
