nginx-ingress-integrator
Nginx Ingress Integrator
latest/stable 203 09 Sep 2025
Ubuntu 22.04 Ubuntu 20.04
latest/stable 202 09 Sep 2025
latest/stable 144 09 Sep 2025
latest/stable 145 09 Sep 2025
latest/stable 101 28 May 2024
latest/edge 414 Yesterday
latest/edge 413 Yesterday
latest/edge 145 13 Mar 2025
latest/edge 144 13 Mar 2025
latest/edge 109 22 Jul 2024
v2/edge 84 09 Jan 2024
Ubuntu 20.04
juju deploy nginx-ingress-integrator --channel v2/edge
How to secure an Ingress with TLS.
Requirements
You will need:
  • A laptop or desktop running Ubuntu (or you can use a VM).
  • Juju and MicroK8s installed. We’ll also want to make sure the ingress add-on is enabled, which we can do by running microk8s enable ingress.
  • Charmcraft installed.
  • A working nginx-ingress-integrator deployment.
  • OpenSSL installed.
Creating the TLS secret
For the sake of simplicity you’ll create a self-signed SSL certificate for the tutorial, but feel free to add SSL
certificates of other types.
For the creation of the Certificate Authority key execute:
openSSL genrsa -out ca.key 2048
And for the creation of the certificate itself:
openssl req -x509 -new -nodes -days 365 -key ca.key -out ca.crt -subj "/CN=exampledomain.com"
With the CA key and cert created, create the actual Kubernetes secret with:
microk8s kubectl create secret tls my-tls-secret --key ca.key --cert ca.crt
After the secret creation you can check the secret by running:
microk8s kubectl get secrets/my-tls-secret
microk8s kubectl describe secrets/my-tls-secret
At last, relate the nginx-ingress-integrator charm with the MicroK8s TLS secret by setting the config option:
juju config nginx-ingress-integrator tls-secret-name="my-tls-secret"
Now your NGINX Ingress integrator is secured with TLS.
