NetBox K8S Charm
latest/edge 3 12 Sep 2025
4/stable 19 24 Oct 2025
Ubuntu 24.04
4/edge 46 27 Apr 2026
Ubuntu 24.04
juju deploy netbox-k8s --channel 4/edge
How to contribute
Overview
This document explains the processes and practices recommended for contributing enhancements to the NetBox NetBox K8s operator.
  • Generally, before developing enhancements to this charm, you should consider opening an issue explaining your use case.
  • If you would like to chat with us about your use-cases or proposed implementation, you can reach us at Canonical Matrix public channel or Discourse.
  • Familiarising yourself with the Charmed Operator Framework library will help you a lot when working on new features or bug fixes.
  • All enhancements require review before being merged. Code review typically examines:
    • code quality
    • test coverage
    • user experience for Juju operators of this charm
  • Please help us out in ensuring easy to review branches. Rebase your pull request branch onto the main branch. This also avoids merge commits and creates a linear Git commit history.
Developing
The code for this charm can be downloaded as follows:
git clone https://github.com/canonical/netbox-k8s-operator
You can use the environments created by tox for development:
tox --notest -e unit
source .tox/unit/bin/activate
Testing
Note that the NetBox image needs to be built and pushed to MicroK8s for the tests to run. They should be tagged as localhost:32000/netbox:latest so that Kubernetes knows how to pull them from the MicroK8s repository. Note that the MicroK8s registry needs to be enabled using microk8s enable registry. More details regarding the OCI images below. The following commands can then be used to run the tests:
  • tox: Runs all of the basic checks (lint, unit, static, and coverage-report).
  • tox -e fmt: Runs formatting using black and isort.
  • tox -e lint: Runs a range of static code analysis to check the code.
  • tox -e static: Runs other checks such as bandit for security issues.
  • tox -e unit: Runs the unit tests.
  • tox -e integration: Runs the integration tests.
Build charm
Build the charm in this git repository using:
charmcraft pack
For the integration tests (and also to deploy the charm locally), the netbox image is required in the MicroK8s registry. To enable it:
The following commands import the images in the Docker daemon and push them into the registry:
    cd [project_dir] && rockcraft pack
    rockcraft.skopeo --insecure-policy copy --dest-tls-verify=false oci-archive:netbox_0.1_amd64.rock docker://localhost:32000/netbox:latest
Deploy
# Create a model
juju add-model netbox-dev
# Enable DEBUG logging
juju model-config logging-config="<root>=INFO;unit=DEBUG"
# Deploy the charm (assuming you're on amd64)
juju deploy ./netbox-k8s_ubuntu-22.04-amd64.charm \
  --resource django-app-image=localhost:32000/netbox:latest
Configure
NetBox requires a Redis integration to work correctly. This can be done with:
juju deploy redis-k8s --channel=latest/edge
juju integrate redis-k8s netbox-k8s
NetBox is built using Django. It is necessary to set the allowed hosts for it to work. For development (not recommended for production environments), you can allow all hosts using the configuration option django-allowed-hosts like:
juju config netbox-k8s django-allowed-hosts='*'
The NetBox charm requires a postgresql_client interface to work. Thanks to Juju, this can be easily configured with:
juju deploy postgresql-k8s --channel 14/stable --trust
juju wait-for application postgresql-k8s
juju integrate postgresql-k8s netbox-k8s
Canonical contributor agreement
Canonical welcomes contributions to the NetBox K8s Operator. Please check out our contributor agreement if you’re interested in contributing to the solution.
