NetBox K8S Charm
| latest/edge | 3 | 12 Sep 2025 | |
| 4/stable | 19 | 24 Oct 2025 | |
| 4/edge | 46 | 27 Apr 2026 |
juju deploy netbox-k8s --channel 4/edge
Configure OIDC
The NetBox charm makes use of the oauth integration for OIDC. You can find more information in charmhub.
OIDC is configured in NetBox using the library python-social-core with the OIDC backend.
To configure it, you only need to integrate your OIDC provider with NetBox K8s:
juju integrate hydra netbox-k8s
For NetBox to work, you may need to customise some of the following configuration options:
oidc-scopes: OIDC scopes are used by an application during authentication to authorize access to a user’s details, like name and picture. It must includeopenidto be a valid OIDC.oidc-redirect-path: The redirect URL used by the OIDC provider to redirect back to NetBox application after the authorization is done.
NetBox configuration options for OIDC can be configured like:
juju config netbox-k8s oidc-scopes="openid profile email" oidc-redirect-path="/oauth/complete/oidc/"
