NetBox K8S Charm
latest/edge 3 12 Sep 2025
4/stable 19 24 Oct 2025
Ubuntu 24.04
4/edge 46 27 Apr 2026
Ubuntu 24.04
juju deploy netbox-k8s --channel 4/edge
Charm architecture
The NetBox K8s charm initial version has been generated with the help of the paas-charm project. The paas-charm project provides many of the functionalities needed by this charm like:
  • PostgreSQL integration
  • Redis integration
  • Django migrations
  • Ingress integration
  • COS (Prometheus metrics and Loki logs for gunicorn).
  • OIDC integration.
  • S3 integration.
For the static assets, gunicorn is used with the help of the WhiteNoiseMiddleware.
There is only one container for each unit of NetBox K8s that runs the following services managed by Pebble:
  • django: runs gunicorn.
  • cron: periodically runs the housekeeping and syncdatasource management commands.
  • statsd_exporter: exposes gunicorn metrics.
The NetBox K8s charm is designed for a high availability (HA) environment. The NetBox application can be scaled to more than one unit to provide HA. See Configure Scripts and Reports for HA for the requirements to use scripts and reports in HA configuration.
