Temporary performance degradation
We are currently experiencing service degradation and working on resolving this. Thank you for your patience and understanding.
24.04 23.10 23.04 22.10 22.04 21.10 21.04 20.10 20.04
latest/edge 1113 09 Apr 2026
Ubuntu 24.04 Ubuntu 23.10 Ubuntu 23.04 Ubuntu 22.10 Ubuntu 22.04 Ubuntu 20.04
latest/edge 1112 09 Apr 2026
latest/edge 1111 09 Apr 2026
latest/edge 1110 09 Apr 2026
latest/edge 201 19 Jun 2024
latest/edge 108 12 Sep 2023
latest/edge 62 10 Feb 2023
8.0/stable 257 17 Oct 2024
dpe/candidate 362 22 Jan 2026
dpe/candidate 1093 22 Jan 2026
dpe/candidate 1091 22 Jan 2026
dpe/candidate 1092 22 Jan 2026
dpe/beta 362 22 Jan 2026
dpe/beta 1093 22 Jan 2026
dpe/beta 1091 22 Jan 2026
dpe/beta 1092 22 Jan 2026
dpe/edge 1105 24 Mar 2026
dpe/edge 1104 24 Mar 2026
dpe/edge 1103 24 Mar 2026
dpe/edge 362 31 Mar 2025
8.4/edge 1099 17 Feb 2026
Ubuntu 24.04
8.4/edge 1098 17 Feb 2026
Ubuntu 24.04
8.4/edge 1097 17 Feb 2026
Ubuntu 24.04
8.0.19/stable 26 05 May 2022
8.0.19/edge 26 05 May 2022
Ubuntu 22.04 Ubuntu 21.10 Ubuntu 21.04 Ubuntu 20.10 Ubuntu 20.04
8.0.19/edge 15 26 Apr 2022
juju deploy mysql-router --channel 8.4/edge
Legacy charms
This page contains explanations regarding the legacy version of this charm. This includes clarification about Charmhub tracks, supported endpoints and interfaces, config options, and other important information.
Charm types: “legacy” vs. “modern”
There are two types of charms stored under the same charm name mysql-router:
  1. Reactive charm in the channel latest/stable, 8.0/stable, 8.0.19/stable (called legacy)
  2. Ops-based charm in the channel dpe/candidate, 8.4/edge (called modern)
Both legacy and modern charms are subordinated.
The legacy charm provided SQL endpoints shared-db (for the interface mysql-shared). The modern charm provides those old endpoint and a new endpoint database (for the interface mysql_client). Read more details about the available endpoints and interfaces here.
Note: Please choose one endpoint to use. No need to relate all of them simultaneously!
Default track latest/ vs. track 8.4/
The default track will be switched from the latest to 8.4 soon. This is to ensure all new deployments use a modern codebase. We strongly advise against using the latest track, since a future charm upgrade may result in a MySQL Router version incompatible with an integrated application. Track 8.4/ guarantees a major router version 8.4 deployment only. The track latest/ will be closed after all applications migrated from reactive to the ops-based charm.
How to migrate to the modern charm
The modern charm provides temporary support for the legacy interfaces:
Quick try: relate the current application with new charm using endpoint shared-db (set the channel to dpe/candidate). No extra changes necessary:
  mysql-router:
    charm: mysql-router
    channel: dpe/candidate
Proper migration: migrate the application to the new interface mysql_client. The application will connect MySQl Router using the data_interfaces library from data-platform-libs via the endpoint database.
Warning: In-place upgrades are NOT possible! The reactive charm cannot be upgraded to the operator-framework-based one. The second/modern charm application must be launched nearby and relations should be switched from the legacy application to the modern one.
How to deploy the legacy charm
Deploy the charm using the channel latest/stable:
  mysql-router:
    charm: mysql-router
    channel: 8.0/stable
Note: remove Charm store prefix cs: from the bundle. Otherwise the modern charm will be chosen by Juju (due to the default track will be pointing to 8.4/stable and not latest/stable). The common error message is: cannot deploy application "mysql-router": unknown option "...".
Features supported by the modern charm
This section goes over the key differences in feature support and functionality between the legacy and modern charm.
Config options
The legacy charm config options were not moved to the modern charm, since the modern charm applies the best possible configuration automatically. Feel free to contact us about the MySQl Router config options.
Extensions
Both legacy and modern charms provide no plugins/extensions support.
MySQL versions
At the moment, the modern MySQL Router charm supports relation to the modern Charmed MySQL 8.0 (based on Jammy/22.04 series) only. Please contact us if you need different versions/series.
Architectures
Currently, the modern charm supports architecture amd64 and arm64 only.
Report issues
The “legacy charm” (from latest/stable) is stored on Launchpad. Report legacy charm issues here.
The “modern charm” (from dpe/candidate) is stored on GitHub. Report modern charm issues here.
Do you have questions? Reach out to us!
Help improve this document in the forum (guidelines). Last updated 1 year, 8 months ago.
