| 8.0/stable | 902 | 30 Mar 2026 | |
| 8.0/stable | 903 | 30 Mar 2026 | |
| 8.0/stable | 904 | 30 Mar 2026 | |
| 8.0/candidate | 902 | 24 Mar 2026 | |
| 8.0/candidate | 903 | 24 Mar 2026 | |
| 8.0/candidate | 904 | 24 Mar 2026 | |
| 8.0/beta | 902 | 24 Mar 2026 | |
| 8.0/beta | 903 | 24 Mar 2026 | |
| 8.0/beta | 904 | 24 Mar 2026 | |
| 8.0/edge | 904 | 24 Mar 2026 | |
| 8.0/edge | 903 | 24 Mar 2026 | |
| 8.0/edge | 902 | 24 Mar 2026 | |
| 8.4/edge | 879 | 17 Feb 2026 | |
| 8.4/edge | 878 | 17 Feb 2026 | |
| 8.4/edge | 873 | 17 Feb 2026 |
juju deploy mysql-router-k8s --channel 8.4/edge
Juju version
The charm supports both Juju 2.9 LTS and Juju 3.1.
The minimum supported Juju versions are:
- 2.9.32+
- 3.1.7+ (Juju secrets refactored/stabilized in Juju 3.1.7)
Kubernetes requirements
- Kubernetes 1.27+
- Canonical MicroK8s 1.27+ (snap channel 1.27-strict/stable and newer)
Minimum requirements
Make sure your machine meets the following requirements:
- Ubuntu 22.04 (Jammy) or later.
- 8GB of RAM.
- 2 CPU threads.
- Access to the internet for downloading the required OCI/ROCKs and charms.
Supported architectures
The charm is based on ROCK OCI named “charmed-mysql”, which is recursively based on SNAP “charmed-mysql”, which is currently available for amd64 and arm64 only! Please contact us if you are interested in new architecture!
Charmed MySQL K8s requirements
- Please also keep in mind “Charmed MySQL K8s” requirements.
