| 8.0/stable | 902 | 30 Mar 2026 | |
| 8.0/stable | 903 | 30 Mar 2026 | |
| 8.0/stable | 904 | 30 Mar 2026 | |
| 8.0/candidate | 902 | 24 Mar 2026 | |
| 8.0/candidate | 903 | 24 Mar 2026 | |
| 8.0/candidate | 904 | 24 Mar 2026 | |
| 8.0/beta | 902 | 24 Mar 2026 | |
| 8.0/beta | 903 | 24 Mar 2026 | |
| 8.0/beta | 904 | 24 Mar 2026 | |
| 8.0/edge | 904 | 24 Mar 2026 | |
| 8.0/edge | 903 | 24 Mar 2026 | |
| 8.0/edge | 902 | 24 Mar 2026 | |
| 8.4/edge | 879 | 17 Feb 2026 | |
| 8.4/edge | 878 | 17 Feb 2026 | |
| 8.4/edge | 873 | 17 Feb 2026 |
juju deploy mysql-router-k8s --channel 8.4/edge
Note: All commands are written for juju >= v3.0
How to enable monitoring with COS and Grafana
This guide goes over the steps to integrate MySQL Router K8s deployment with COS to enable monitoring in Grafana.
To learn about Alert Rules, see Charmed MySQL K8s > How to enable COS Alert Rules.
- A deployed Charmed MySQL Router K8s operator
- A deployed ‘cos-lite’ bundle in a Kubernetes environment
- Offer interfaces via the COS controller
- Consume offers via the MySQL Router K8s model
- Deploy and integrate Grafana
- Connect to the Grafana web interface
First, we will switch to the COS K8s environment and offer COS interfaces to be cross-model integrated with the Charmed MySQLRouter K8s model.
To switch to the Kubernetes controller for the COS model, run
juju switch <k8s_controller>:<cos_model_name>
To offer the COS interfaces, run
juju offer grafana:grafana-dashboard
juju offer loki:logging
juju offer prometheus:receive-remote-write
Next, we will switch to the Charmed MySQL Router K8s model, find offers, and consume them.
We are currently on the Kubernetes controller for the COS model. To switch to the MySQL Router K8smodel, run
juju switch <k8s_db_controller>:<mysql_router_model_name>
Display a list of available interfaces with the following command:
juju find-offers <k8s_cos_controller>: # Do not miss the ':' here!
In the sample output below, k8s is the k8s controller name and cos is the model where cos-lite has been deployed:
Store URL Access Interfaces
k8s admin/cos.grafana admin grafana_dashboard:grafana-dashboard
k8s admin/cos.loki admin loki_push_api:logging
k8s admin/cos.prometheus admin prometheus_remote_write:receive-remote-write
To consume offers to be reachable in the current model, run
juju consume k8s:admin/cos.grafana
juju consume k8s:admin/cos.loki
juju consume k8s:admin/cos.prometheus
First, deploy grafana-agent:
juju deploy grafana-agent-k8s --trust
Then, integrate (previously known as “relate”) grafana-agent with Charmed MySQL Router K8s:
juju integrate grafana-agent-k8s grafana
juju integrate grafana-agent-k8s loki
juju integrate grafana-agent-k8s prometheus
Finally, integrate grafana-agent-k8s with the consumed COS offers:
juju integrate grafana-agent-k8s mysql-router-k8s:grafana-dashboard
juju integrate grafana-agent-k8s mysql-router-k8s:logging
juju integrate grafana-agent-k8s mysql-router-k8s:metrics-endpoint
After this is complete, Grafana will show the new dashboards MySQLRouter Exporter and allow access for Charmed MySQL Router K8s logs on Loki.
An example of juju status on Charmed MySQL Router K8s model:
ubuntu@localhost:~$ juju status
database k8s microk8s/localhost 3.1.8 unsupported 13:27:08Z
SAAS Status Store URL
grafana active k8s admin/cos.grafana
loki active k8s admin/cos.loki
prometheus active k8s admin/cos.prometheus
grafana-agent-k8s 0.35.2 active 1 grafana-agent-k8s stable 64 10.152.183.141 no
mysql-k8s 8.0.35-0ubuntu0.22.04.1 active 1 mysql-k8s 8.0/stable 127 10.152.183.105 no
mysql-router-k8s 8.0.36-0ubuntu0.22.04.1 active 1 mysql-router-k8s 8.0/edge 102 10.152.183.92 no
mysql-test-app 0.0.2 active 1 mysql-test-app stable 36 10.152.183.35 no
grafana-agent-k8s/0* active idle 10.1.241.243
mysql-k8s/0* active idle 10.1.241.239 Primary
mysql-router-k8s/0* active idle 10.1.241.240
mysql-test-app/0* active idle 10.1.241.241
An example of juju status on the COS K8s model:
cos k8s microk8s/localhost 3.1.8 unsupported 13:28:02Z
alertmanager 0.27.0 active 1 alertmanager-k8s stable 106 10.152.183.197 no
catalogue active 1 catalogue-k8s stable 33 10.152.183.38 no
grafana 9.5.3 active 1 grafana-k8s stable 106 10.152.183.238 no
loki 2.9.4 active 1 loki-k8s stable 124 10.152.183.84 no
prometheus 2.49.1 active 1 prometheus-k8s stable 171 10.152.183.182 no
traefik 2.10.5 active 1 traefik-k8s stable 174 10.0.0.44 no
alertmanager/0* active idle 10.1.241.222
catalogue/0* active idle 10.1.241.225
grafana/0* active idle 10.1.241.228
loki/0* active idle 10.1.241.226
prometheus/0* active idle 10.1.241.227
traefik/0* active idle 10.1.241.221
Offer Application Charm Rev Connected Endpoint Interface Role
grafana grafana grafana-k8s 106 2/2 grafana-dashboard grafana_dashboard requirer
loki loki loki-k8s 124 2/2 logging loki_push_api provider
prometheus prometheus prometheus-k8s 171 2/2 receive-remote-write prometheus_remote_write provider
Connect to Grafana web interface
To connect to the Grafana web interface, follow the Browse dashboards section of the MicroK8s “Getting started” guide.
juju run grafana/leader get-admin-password --model <k8s_controller>:<cos_model_name>
