mongos-k8s
| 6/stable | 75 | 23 Jan 2026 | |
| 6/candidate | 75 | 23 Jan 2026 | |
| 6/beta | 75 | 23 Jan 2026 | |
| 6/edge | 137 | 30 Apr 2026 | |
| 8-transition/edge | 139 | 30 Apr 2026 | |
| 8-transition/edge | 138 | 30 Apr 2026 | |
| 8/stable | 74 | 23 Jan 2026 | |
| 8/candidate | 74 | 23 Jan 2026 | |
| 8/beta | 74 | 23 Jan 2026 | |
| 8/edge | 143 | 05 May 2026 | |
| 8/edge | 142 | 05 May 2026 |
juju deploy mongos-k8s --channel 8-transition/edge
Advanced Statuses
MongoDB charms leverages Advanced Statuses to provide and expose detailed, component-specific status information. This interface supports more complex and multiple statuses.
Basics
Advanced Statuses are implemented in the homebrewed Data Platform Helpers library.
Each component of the charm recomputes its statuses on every status-update event, and will sort the statuses by order of importance.
They are first order like ops does: Error > Blocked > Maintenance > Waiting > Active > Unknown and then by component priority for an equal status level.
If multiple important (understand Blocked, Maintenance or Waiting) are
reported, a special status is computed. This status has the priority of the
most important status, and its message is the following:
"<status message>. Run `status-detail`: X action required; Y additional statuses")
For example, the following juju status output shows an aggregated status for a charmed-mongodb sharded deployment.
integ-test overlord localhost/localhost 3.6.8 unsupported 16:17:23+02:00
application active 1 application 0 no
config-server 8.0.10 active 1 mongodb 0 no
config-server-two 8.0.10 active 1 mongodb 1 no
data-integrator blocked 1 data-integrator latest/stable 180 no Please specify either topic, index, database name, or prefix
mongos unknown 0 mongos 0 no
replication 8.0.10 active 1 mongodb 3 no
s3-integrator active 1 s3-integrator latest/edge 192 no
self-signed-certificates active 1 self-signed-certificates latest/stable 264 no
shard-one 8.0.10 active 1 mongodb 2 no
application/0* active idle 7 10.137.178.161
config-server-two/0* blocked idle 1 10.137.178.124 27017-27018/tcp Missing relation to shard(s).
config-server/0* blocked idle 0 10.137.178.103 27017-27018/tcp Sharding roles do not support database i... Run `status-detail`: 1 action required; 2 additional statuses.
data-integrator/0* blocked idle 5 10.137.178.241 Please specify either topic, index, database name, or prefix
replication/0* active idle 6 10.137.178.242 27017/tcp Primary.
s3-integrator/0* active idle 4 10.137.178.92
self-signed-certificates/0* active idle 3 10.137.178.134
shard-one/0* blocked idle 2 10.137.178.63 27017/tcp Missing relation to config-server.
0 started 10.137.178.103 juju-86c745-0 ubuntu@24.04 Running
1 started 10.137.178.124 juju-86c745-1 ubuntu@24.04 Running
2 started 10.137.178.63 juju-86c745-2 ubuntu@24.04 Running
3 started 10.137.178.134 juju-86c745-3 ubuntu@22.04 Running
4 started 10.137.178.92 juju-86c745-4 ubuntu@22.04 Running
5 started 10.137.178.241 juju-86c745-5 ubuntu@24.04 Running
6 started 10.137.178.242 juju-86c745-6 ubuntu@24.04 Running
7 started 10.137.178.161 juju-86c745-7 ubuntu@24.04 Running
Due to their extended structure, advanced statuses contain more information than regular ones, providing developers with valuable hints for operators. They can specify an action to run to resolve a status and indicate which check led to the status being computed.
Statuses can be set as critical so that they override the regular flow and are displayed no matter what happens if they require immediate action.
status-detail action
The status-detail action is a helper that provides extended access to the charm statuses.
Running this action will display all application and unit statuses. It includes an optional recompute argument that allows for status re-evaluation. When recompute is used, the system re-computes statuses for non-leader units and all statuses for leader units.
Note: Though the recompute flag will yield the most up-to-date status of the application, it can also come with a performance penalty depending on the list of deployed components.
This action is particularly useful for debugging and understanding the charm’s current state, as it provides a detailed view of all statuses, including those not visible in the standard status output.
Running the status-detail action produces output similar to the following (example run on a mongodb config-server unit, though we should expect a similarly formatted output when running this action against a mongos-k8s unit):
juju run config-server/0 status-detail
Running operation 9 with 1 task
- task 10 on unit-config-server-0
Waiting for task 10...
16:16:55 Stored statuses:
16:16:55 App Statuses
| Status | Component Name | Message | Action | Reason |
| Active | upgrade | | N/A | N/A |
16:16:55 Unit Statuses
| Blocked | mongod | Sharding roles do | N/A | N/A |
| | | not support | | |
| | | database | | |
| | | interface. | | |
| Blocked | backup | s3 configurations | N/A | N/A |
| | | missing. | | |
| Blocked | backup | s3 credentials are | Check S3 | N/A |
| | | incorrect. | credentials on | |
| | | | s3-integrator | |
| Active | mongo | Primary. | N/A | N/A |
json-output:
app: '[{"Status": "Active", "Component Name": "upgrade", "Message": "", "Action":
"N/A", "Reason": "N/A"}]'
unit: '[{"Status": "Blocked", "Component Name": "mongod", "Message": "Sharding roles
do not support database interface.", "Action": "N/A", "Reason": "N/A"}, {"Status":
"Blocked", "Component Name": "backup", "Message": "s3 configurations missing.",
"Action": "N/A", "Reason": "N/A"}, {"Status": "Blocked", "Component Name": "backup",
"Message": "s3 credentials are incorrect.", "Action": "Check S3 credentials on
s3-integrator", "Reason": "N/A"}, {"Status": "Active", "Component Name": "mongo",
"Message": "Primary.", "Action": "N/A", "Reason": "N/A"}, {"Status": "Active",
"Component Name": "upgrade", "Message": "", "Action": "N/A", "Reason": "N/A"}]'
This output provides a comprehensive view of statuses, detailing component names, messages, actions, and reasons for each status. The json-output section at the end offers a structured format, which is ideal for parsing by automation tools and scripts.
Developing with advanced statuses
With advanced statuses, the charm never sets statuses directly but goes through the Data Platform Helpers advanced statuses module.
While documentation is available in the library, keep these key points in mind:
- Add new statuses to the status collection in
src/statuses.py. - Ensure your manager inherits from the
ManagerStatusProtocol. - Implement the
get_statuses(scope, recompute)method within your manager. - Add your manager to the list of those that report statuses in
src/charm.py.
