![mongodb-k8s](https://res.cloudinary.com/canonical/image/fetch/f_auto,q_auto,fl_sanitize,c_fill,w_100,h_100/https://api.charmhub.io/api/v1/media/download/charm_UUQcdJOSAfUQYBmFoNRuBw3giz1ebvGS_icon_ad1a94cf9bb9f68614cb6c17e54e2fbd9dcc7fecc514dc6012b7f58fb5b87f8f.png)
Charmed Operator for MongoDB
- Canonical
6/stable | 61 | 15 Nov 2024 | |
6/candidate | 61 | 15 Nov 2024 | |
6/beta | 61 | 15 Nov 2024 | |
6/edge | 62 | 12 Feb 2025 | |
5/edge | 39 | 14 Dec 2023 |
A complete, detailed tutorial about deploying and operating a sharded cluster on MongoDB K8s is currently under construction. Thank you for your patience!
In the meantime, you can:
- See MongoDB VM Tutorial > Deploy a sharded cluster
- Continue reading for alternative documentation that can guide you through most tutorial steps.
Here are all the steps you need to learn how to deploy and operate a sharded cluster on MongoDB K8s, including setting up and tearing down a test environment.
1. Set up your environment
See: Tutorial > Deploy a replica set > 1. Set up your environment
The environment setup process (Juju, MicroK8s) is independent of the deployment type (replica set or sharded cluster).
2. Deploy MongoDB
See: How to > Deploy MongoDB > Create a MongoDB sharded cluster
3. Access a sharded cluster
To deploy, integrate, and retrieve the URI, see: Mongos K8s documentation > Get started (external page)
To access the mongo
shell and create a test database, see Tutorial > Deploy a replica set > 3. Access a replica set
Keep in mind that for a sharded cluster, you must ssh
into the config-server
unit instead of mongodb-k8s
4. Add and remove shards
See: How to > Scale replicas and shards > Scale a sharded cluster
5. Manage passwords
See: How to > Manage client connections > Rotate mongos
password
6. Integrate with other applications
See: How to > Manage client connections > Create a client connection to a sharded cluster
7. Enable TLS
See: How to > Enable TLS encryption > Enable and disable TLS in a sharded cluster
8. Clean up your environment
See: Tutorial > Deploy a replica set > 8. Clean up your environment
The environment cleanup process is independent of the deployment type (replica set or sharded cluster).
