Charmed Operator for MongoDB
- Canonical
6/stable | 61 | 15 Nov 2024 | |
6/candidate | 61 | 15 Nov 2024 | |
6/beta | 61 | 15 Nov 2024 | |
6/edge | 63 | 12 Mar 2025 | |
5/edge | 39 | 14 Dec 2023 |
Charmed MongoDB K8s Tutorials > 1. Set up the environment
Charmed MongoDB K8s is operated via Juju, a charm orchestration engine that makes them easy to operate. For this tutorial, we will set up the tools needed to deploy and use Charmed MongoDB K8s.
- Minimum requirements for your machine
- Set up MicroK8s
- Set up Juju
Before we start, make sure your machine meets the following requirements:
- Ubuntu 22.04 (Jammy)
- 8GB of RAM
- 2 CPU threads
- At least 20GB of available storage
- Access to the internet for downloading the required snaps and charms
Set up MicroK8s
MicroK8s is a lightweight Kubernetes for automating deployment, scaling, and management of containerised applications. Charmed MongoDB K8s will be run in Kubernetes pods and managed by Juju.
Install
Because we will use juju 3.x which is a strictly confined snap, we also need to install strict MicroK8s:
sudo snap install microk8s --channel=1.27-strict
Configure
Add your user to the microk8s
group:
sudo usermod -a -G snap_microk8s $(whoami)
Create a ~/.kube
folder and set permissions:
mkdir ~/.kube
sudo chown -R $(whoami) ~/.kube
Reload the user groups either via a reboot or by running the following command:
newgrp snap_microk8s
Check the status of Kubernetes:
microk8s status --wait-ready
Enable some required plugins:
sudo microk8s enable dns storage ingress
Create an alias for microk8s.kubectl
sudo snap alias microk8s.kubectl kubectl
This alias is optional but recommended for this tutorial, since future
kubectl
commands will use this alias.
Set up juju
Juju is an Operator Lifecycle Manager (OLM) for clouds, bare metal, LXD or Kubernetes. We will be using it to deploy and manage Charmed MongoDB K8s.
Install
As with MicroK8s, Juju is installed from a snap package:
sudo snap install juju --classic --channel=3.1
Juju already has a built-in knowledge of Kubernetes and how it works, so there is no additional setup or configuration needed. A controller will be used to deploy and control Charmed MongoDB K8s.
Configure
Because Juju v3.x is a strictly confined snap, it is not allowed to create ~/.local/share
automatically. We must create it manually:
mkdir -p $HOME/.local/share/juju
Bootstrap a juju controller
A Juju controller will be used to deploy and control Charmed MongoDB K8s. All we need to do is run the following command to bootstrap a controller named ‘overlord’ to MicroK8s. This bootstrapping processes can take several minutes depending on how provisioned (RAM, CPU, etc.) your machine is:
juju bootstrap microk8s overlord
The Juju controller should exist within a Kubernetes namespace. Verify this by displaying the namespaces and pods via kubectl
To see the namespaces, run
kubectl get namespaces
Output:
NAME STATUS AGE
kube-system Active <age>
kube-public Active <age>
kube-node-lease Active <age>
default Active <age>
ingress Active <age>
controller-overlord Active <age>
To see the pods in our controller, run
kubectl get pods --namespace=controller-overlord
Output:
NAME READY STATUS RESTARTS AGE
controller-0 2/2 Running 1 (<restarted> ago) <age>
modeloperator-6c58d95cfb-ktts7 1/1 Running 0 <age>
<age>
shows how long ago a namespace was created and<restarted>
shows when the pod was last restarted.
Add a model
The controller can work with different juju models. Models host charmed applications such as Charmed MongoDB K8s.
Set up a specific model for our MongoDB K8s deployment named ‘tutorial’:
juju add-model tutorial
You can now view the model you created above by entering the command juju status
into the command line. You should see the following:
tutorial overlord microk8s/localhost 3.1.5 unsupported 11:35:46Z
Model "admin/tutorial" is empty.
Next step: 2. Deploy MongoDB
