mongodb-k8s
Charmed Operator for MongoDB
6/stable 81 20 Aug 2025
6/candidate 81 20 Aug 2025
6/beta 81 20 Aug 2025
6/edge 97 20 Nov 2025
8-transition/edge 98 20 Nov 2025
Ubuntu 24.04
8/stable 95 18 Nov 2025
Ubuntu 24.04
8/candidate 95 18 Nov 2025
Ubuntu 24.04
8/beta 95 18 Nov 2025
Ubuntu 24.04
8/edge 102 10 Dec 2025
Ubuntu 24.04
How to scale replicas and shards
In this guide, you will find instructions on how to scale your MongoDB K8s replica set and sharded cluster.
Scale a replica set
To scale a replica set, use juju’s add-unit and remove-unit commands.
Add replicas
To add more replicas, run:
juju add-unit <application_name> -n <num_of_replicas_to_add>
Where an application can be either a bare replica set, shard, or config-server.
Remove replicas
remove-unit allows removing more than one replica so long as they do not constitute the majority of the replicas.
To remove replicas, run:
juju remove-unit <application_name>/<unit_number> <application_name>/<unit_number>
Retrieve primary replica
To retrieve the primary replica, use the juju action get-primary:
juju run <application_name>/<unit_number> get-primary
Scale a sharded cluster
Add shards to a cluster
To add a shard to a cluster, first deploy the new shard.
To deploy a shard named new-shard, run:
juju deploy mongodb-k8s --config role="shard" new-shard -n <number of replicas for shard>
Wait for the shard to show blocked and idle with juju status --watch 1s.
Next, add it to your config-server:
juju integrate <config-server-name>:config-server new-shard:sharding
Remove shards from a cluster
Like official MongoDB, Charmed MongoDB K8s does not support removing the last shard.
To remove a shard named new-shard that is not the last, run:
juju remove-relation <config-server-name>:config-server new-shard:sharding
You can watch your sharded cluster scale down with juju status --watch 1s.
Once the shard is drained, you can fully remove it with:
juju remove-application new-shard
Help improve this document in the forum (guidelines). Last updated 1 year, 2 months ago.
