| 6/stable | 81 | 20 Aug 2025 | |
| 6/candidate | 81 | 20 Aug 2025 | |
| 6/beta | 81 | 20 Aug 2025 | |
| 6/edge | 97 | 20 Nov 2025 | |
| 8-transition/edge | 98 | 20 Nov 2025 | |
| 8/stable | 95 | 18 Nov 2025 | |
| 8/candidate | 95 | 18 Nov 2025 | |
| 8/beta | 95 | 18 Nov 2025 | |
| 8/edge | 102 | 10 Dec 2025 |
How to migrate to a new a cluster via restore
This page contains the steps needed to prepare for and perform a restore of a backup from a different cluster, i.e. cluster migration via restore.
We will use the following terms:
- new cluster - the backed-up cluster that we will migrate data from.
- old cluster - the currently active cluster that will be restored to the state of the new cluster.
- For bare replica sets:
- The new cluster has a number of replicas equal to or greater than the old cluster.
- E.g. Your old cluster had 2 replicas, so your new cluster must have 2 or more replicas
- See How To > Scale replicas and shards
- For sharded clusters:
- The new cluster has a number of shards and replicas equal to or greater than those in the old cluster.
- E.g. Your old cluster had 2 shards, so your new cluster must have 2 or more shards.
- E.g. Your old shard had 4 replicas, so your new shard must have 4 or more replicas.
- Configured settings for S3 storage
- Backups from the new cluster in your S3 storage
- Password from your new cluster
- Change password of old cluster
- List all backups
- Define remap pattern (sharded cluster only)
- Restore backup
The migration process will restore the password from the new cluster to your old cluster. Set the password of your old cluster to the new cluster’s password:
juju run <replica-set name | config-server name>/leader set-password password=<new cluster password>
List all backups
To view the available backups, enter the command list-backups:
juju run <replica-set name | config-server name>/leader list-backups
This shows a list of the available backups similar to the output below. Identify which backup-id corresponds to the new cluster.
backup-id | backup-type | backup-status
YYYY-MM-DDTHH:MM:SSZ | logical | finished
If you are running Charmed MongoDB K8s as a bare replica set, you can skip this step.A remap pattern is a pattern that specifies which old components should be migrated to which new components. They are used when we are migrating to a cluster with new names.
If you are running Charmed MongoDB K8s as a sharded cluster and you wish to migrate to a cluster with new names, you must generate a remap pattern.
The following example shows how to create a remap pattern for a sample cluster migration.
Sample old cluster:
old-mod overlord localhost/localhost 3.1.6 unsupported 17:27:22Z
application active 1 application 0 no
config-server active 1 mongodb-k8s 6/stable 158 no
shard-one active 1 mongodb-k8s 6/stable 158 no
shard-two active 1 mongodb-k8s 6/stable 158 no
application/0* active idle 10.130.84.77
config-server/0* active idle 10.130.84.120
self-signed-certificates/0* active idle 10.130.84.32
shard-one/0* active idle 10.130.84.78
shard-two/0* active idle 10.130.84.68
Sample new cluster:
new-mod overlord localhost/localhost 3.1.6 unsupported 17:27:22Z
The following would be a valid remap pattern:
config-server-new=config-server,shard-one-new=shard-one,shard-two-new=shard-two
Restore backup
To restore your current cluster to the state of the previous cluster, run the restore command and pass the correct backup-id to the command:
juju run <replica-set name | config-server name>/leader restore backup-id=YYYY-MM-DDTHH:MM:SSZ [remap-pattern=<remap-pattern>]
Your restore will then be in progress. Once it is complete, your old cluster will represent the state of the new cluster.
