mongodb-k8s
Charmed Operator for MongoDB
6/stable 61 15 Nov 2024
6/candidate 61 15 Nov 2024
6/beta 61 15 Nov 2024
6/edge 63 12 Mar 2025
5/edge 39 14 Dec 2023
How to manage client connections
Integrations (formerly “relations”) are connections between two applications with compatible endpoints. These connections simplify the creation and management of users, passwords, and other shared data.
Create a client connection to a bare replica set
To create a client connection to a replica set, simply integrate your client application with a Charmed MongoDB application running in replication mode.
If you do not have a client application that implements this interface, you can use the data-integrator charm.
To integrate mongodb with a client application, run:
juju integrate mongodb-k8s <application>
Remove a client connection to a replica set
To remove a client connection and the user associated with it:
juju remove-relation mongodb-k8s <application>
Rotate the client password
To rotate the replica-set client password, the integration should be removed and integrated again:
juju remove-relation <application> mongodb-k8s
juju integrate <application> mongodb-k8s
This process will generate a new user and password for the application.
Create a client connection to a sharded cluster
To create a client connection to a sharded cluster, you must use the Charmed Mongos-K8s router.
To deploy mongos-k8s and data-integrator, run:
juju deploy mongos-k8s
juju deploy data-integrator [necessary options]
Wait for mongos-k8s’s status to be idle, then integrate it with data-integrator:
juju integrate mongos-k8s data-integrator
Next, integrate the mongos-k8s charm to a Charmed MongoDB application running as a config-server:
juju integrate config-server mongos-k8s
Remove a client connection to a sharded cluster
To remove a client connection to a sharded cluster:
juju remove-relation config-server mongos-k8s
Rotate the mongos-k8s client password
To rotate client passwords, the integration should be removed and integrated again:
juju remove-relation <application> mongos-k8s
juju integrate <application> mongos-k8s
Then to connect to the sharded MongoDB k8s cluster outside of juju, set the configuration expose-external on the Mongos-k8s Charm.
 juju config mongos-k8s expose-external=nodeport
This will make the mongos router accessible outside of juju and will provide you access to the cluster. You will now see that all of your client URIs have been updated.
For example run:
juju run data-integrator get-credentials
and see that the URI as changed.
To reconfigure the charm to have internal access only run:
 juju config mongos-k8s expose-external=none
Internal operator user
The operator (i.e. admin) user is used internally by Charmed MongoDB K8s. To rotate its password, use the set-password action.
To set a specific password for the operator user, run:
juju run mongodb-k8s/leader set-password password=<password>
To randomly generate a password for the operator user, run:
