| 6/stable | 81 | 20 Aug 2025 | |
| 6/candidate | 81 | 20 Aug 2025 | |
| 6/beta | 81 | 20 Aug 2025 | |
| 6/edge | 97 | 20 Nov 2025 | |
| 8-transition/edge | 98 | 20 Nov 2025 | |
| 8/stable | 95 | 18 Nov 2025 | |
| 8/candidate | 95 | 18 Nov 2025 | |
| 8/beta | 95 | 18 Nov 2025 | |
| 8/edge | 102 | 10 Dec 2025 |
How to view audit logs
Audit logging is enabled by default in Charmed MongoDB K8s.
You can view audit logs in two ways:
View logs using syslog
The audit log is sent to syslog. You can check it by performing the following steps:
First, ssh to the relevant unit. For example:
In the unit’s shell, run:
tail -f /var/log/mongodb/audit.log
The console will now display audit log messages, for example:
Jan 26 13:22:56 juju-f6ba89-2 mongod: { "atype" : "updateOperation", "ts" : { "$date" : "2024-01-26T13:22:56.300+00:00" }, "local" : { "ip" : "10.55.47.232", "port" : 27017 }, "remote" : {}, "users" : [], "roles" : [], "param" : { "ns" : "local.replset.oplogTruncateAfterPoint", "doc" : { "_id" : "oplogTruncateAfterPoint", "oplogTruncateAfterPoint" : { "$timestamp" : { "t" : 1706275376, "i" : 1 } } } }, "result" : 0 }
View logs with Grafana
Audit logs can be viewed with grafana using the Canonical Observability Stack.
To view these logs, you must first integrate Charmed MongoDB K8s with the Canonical Observability Stack. Follow the instructions in How-To > View metrics in the section titled “Accessing metrics with Grafana”.
Once Grafana is active and you are able to access the GUI, navigate to the logging section. There you will be able to see your audit log messages.
