Mimir Coordinator K8S
2/stable 77 16 Mar 2026
Ubuntu 24.04
2/candidate 77 13 Mar 2026
Ubuntu 24.04
2/beta 77 13 Mar 2026
Ubuntu 24.04
2/edge 77 11 Mar 2026
Ubuntu 24.04
dev/edge 81 27 Apr 2026
Ubuntu 24.04
1/stable 43 08 Jul 2025
1/candidate 43 26 Jun 2025
1/beta 43 10 Jun 2025
1/edge 43 14 May 2025
juju deploy mimir-coordinator-k8s --channel 2/edge
        labels:
          model: "some-juju-model"
Dashboards
Metrics
Alert rules
For built-in alert rules,
  • Alert exprs are qualified with topology labels. This way, built-in alerts fire only for the particular charm they originated from.
  • Alert labels are enriched with topology labels. This is meant for convenient reading of a rendered alert when presented to an on-caller. The labels would also be visible in the alert’s rendered expr, but alert labels are more convenient to read.
  • Alert rules are NOT enriched with the unit label. This is because we wouldn’t want to replicated all rules per unit. Unit information is included in metric and log labels. Since alert rules are forwarded to prometheus/loki per related app, not unit, having multiple units does not result in prometheus having duplicated alerts per unit. If an alert was qualified with a unit (which one?), we wouldn’t get alerts from any other units.
  • Alert rules descriptions can use a {{ $labels.juju_unit }} macro in the alert’s annotations, which will be replaced with the unit name for better readability.
Logs
Traces
Additional notes
  • In the future, the grafana-agent charm may start exposing metrics and logs generated by its own workload, and those would be enriched by juju topology labels.
  • In the future, the cos-configuration charm may start exposing metrics and logs generated by its own workload, git-sync, and those would be enriched by juju topology labels.
  • In the future (2025) grafana-agent will be replaced by otlp-collector. The general data flow should remain unchanged.
Help improve this document in the forum (guidelines). Last updated 1 year, 6 months ago.
