Mimir Coordinator K8S
| 2/stable | 77 | 16 Mar 2026 | |
| 2/candidate | 77 | 13 Mar 2026 | |
| 2/beta | 77 | 13 Mar 2026 | |
| 2/edge | 77 | 11 Mar 2026 | |
| dev/edge | 81 | 27 Apr 2026 | |
| 1/stable | 43 | 08 Jul 2025 | |
| 1/candidate | 43 | 26 Jun 2025 | |
| 1/beta | 43 | 10 Jun 2025 | |
| 1/edge | 43 | 14 May 2025 |
juju deploy mimir-coordinator-k8s --channel 1/edge
labels:
model: "some-juju-model"
Dashboards
Metrics
Alert rules
For built-in alert rules,
- Alert
exprs are qualified with topology labels. This way, built-in alerts fire only for the particular charm they originated from. - Alert labels are enriched with topology labels. This is meant for convenient reading of a rendered alert when presented to an on-caller. The labels would also be visible in the alert’s rendered
expr, but alert labels are more convenient to read. - Alert rules are NOT enriched with the
unitlabel. This is because we wouldn’t want to replicated all rules per unit. Unit information is included in metric and log labels. Since alert rules are forwarded to prometheus/loki per related app, not unit, having multiple units does not result in prometheus having duplicated alerts per unit. If an alert was qualified with a unit (which one?), we wouldn’t get alerts from any other units. - Alert rules descriptions can use a
{{ $labels.juju_unit }}macro in the alert’s annotations, which will be replaced with the unit name for better readability.
Logs
Traces
Additional notes
- In the future, the
grafana-agentcharm may start exposing metrics and logs generated by its own workload, and those would be enriched by juju topology labels. - In the future, the
cos-configurationcharm may start exposing metrics and logs generated by its own workload,git-sync, and those would be enriched by juju topology labels. - In the future (2025)
grafana-agentwill be replaced byotlp-collector. The general data flow should remain unchanged.
