Mimir Coordinator K8S
2/stable 77 16 Mar 2026
Ubuntu 24.04
2/candidate 77 13 Mar 2026
Ubuntu 24.04
2/beta 77 13 Mar 2026
Ubuntu 24.04
2/edge 77 11 Mar 2026
Ubuntu 24.04
dev/edge 81 27 Apr 2026
Ubuntu 24.04
1/stable 43 08 Jul 2025
1/candidate 43 26 Jun 2025
1/beta 43 10 Jun 2025
1/edge 43 14 May 2025
juju deploy mimir-coordinator-k8s --channel dev/edge
Mimir provides a scalable and long-term storage solution for metrics, making it a suitable alternative for Prometheus. This How-to will highlight validation steps to provide confidence to the operator that the migration from Prometheus to Mimir is successful without data loss.
Deploy Mimir
Deploy Mimir alongside Prometheus. Then relate Mimir to all the same applications and endpoints that Prometheus has.
Validation
Now we can validate whether Mimir is receiving the same data as Prometheus.
These validations are not exhaustive. More validations can be added to boost migration confidence
Validate metric name outputs
  • juju ssh prometheus/0 curl -g 'http://localhost:9090/api/v1/label/__name__/values' | jq -r ".data[]" | sort -u > prom-metric.txt
  • juju ssh mimir/0 curl -g 'http://localhost:8080/prometheus/api/v1/label/__name__/values' | jq -r ".data[]" | sort -u > mimir-metric-names.txt
Confirm that the same metrics in Prometheus are in Mimir by inspecting diff:
diff -y prom-metrics.txt mimir-metrics.txt
Other validations
Validation Prometheus Mimir
labels api/v1/labels /prometheus/api/v1/labels
app names api/v1/label/juju_application/values prometheus/api/v1/label/juju_application/values
alerts api/v1/rules prometheus/api/v1/rules
For alerts, the API response will result in a large JSON output and we can modify the jq to jq -r ".data[][].name" to aggregate the alert names for validation.
Remove Prometheus
Once the validations are complete, check the config value for metrics_retention_time with the command:
juju config prometheus metrics_retention_time
This is how long samples are retained in the storage (Units Supported: y, w, d, h, m, s). Before deleting Prometheus, this much time must pass prior to removing the Prometheus application to ensure that no data is lost.
Once Prometheus is removed, you are done and you can enjoy a modernized deployment.
Help improve this document in the forum (guidelines). Last updated 1 year, 5 months ago.
