Jenkins K8s
latest/stable 201 29 Sep 2025
Ubuntu 24.04 Ubuntu 22.04
latest/stable 200 29 Sep 2025
latest/edge 311 20 Apr 2026
latest/edge 310 20 Apr 2026
juju deploy jenkins-k8s --channel edge
How to resize the Jenkins home storage volume
The default size of the jenkins-home storage volume for a fresh installation is 1GB. While this works for most scenarios, operators might need to have more storage for installing plugins, storing artifacts, and running builds/checking out SCMs on the built-in node.
A low disk-space on the built-in node will cause the node to go offline, blocking Jenkins from running jobs.
Create a backup of the current Jenkins charm instance
Follow the “Create a backup” section of the charm’s backup and restore documentation to create an archive of the Jenkins data on your host system
Deploy the new Jenkins charm instance, specifying the size of the storage volume
Create a new application with the --storage flag. In this example we’ll deploy the charm with a storage of 10GB:
juju deploy jenkins-k8s-new --storage jenkins-home=10GB
Restore the created backup onto the newly created Jenkins charm instance
Follow the “Restore the backup on a new (or existing) charm instance” section of the charm’s backup and restore documentation to create an archive of the Jenkins data on your host system. Remember to update the JENKINS_UNIT environment variable. For our example we have JENKINS_UNIT=jenkins-k8s-new/0.
Help improve this document in the forum (guidelines). Last updated 7 months ago.
