HTTP Request LEGO (K8s)
latest/stable 99 28 Aug 2024
latest/candidate 99 28 Aug 2024
latest/beta 99 28 Aug 2024
latest/edge 110 20 Jan 2025
juju deploy httprequest-lego-k8s --channel edge
Solving the DNS-01 Challenge
To get a certificate using the httpreq plugin and the DNS-01 challenge from a Certificate Authority that implements the ACME server, we need the following:
  • The Lego Client
  • TLS Certificates Requirer requiring a certificate for a domain name.
  • DNS Agent with an HTTP API
  • DNS Server (Bind as an example)
  • Certificate Authority implementing the ACME protocol (ACME Server)
The diagram below shows how the certificate is acquired by a requirer for their domain name:
  1. The certificate requirer creates a CSR and sets the common name to the domain name that is requiring the certificate, and a request is initiated using the Lego client and the CSR.
  2. The Lego client sends the request to the ACME Server.
  3. The ACME Server will reply with a payload with the content that must be used by the user to create a TXT DNS record to prove their ownership of the domain.
  4. The Lego client makes a request towards the DNS agent to create a TXT DNS record.
  5. The DNS agent will create the TXT record.
  6. The DNS agent confirms the creation of the record through the status code.
  7. The ACME Client tells the ACME Server that the record is in place for the DSN-01 challenge.
  8. The ACME Server will validate the creation of the record.
  9. If the validation of the TXT record was successful, the server will issue the certificate towards the client.
  10. The client delivers the certificate to the requirer.
