Hockeypuck K8S Charm
| latest/edge | 6 | 22 Apr 2025 | |
| 2.2/stable | 20 | 28 May 2025 | |
| 2.2/edge | 74 | 04 Apr 2026 |
juju deploy hockeypuck-k8s --channel latest/edge
Hockeypuck ports
Hockeypuck exposes the following ports for its operation:
- Web App port (11371): This port serves the Hockeypuck web UI as well as its SKS-compatible APIs. It is made externally accessible when the charm is integrated with an ingress controller like traefik-k8s.
- Reconciliation port (11370): This port is used for peering with other SKS-compatible keyservers to synchronize key data. It is accessible via the traefik-route relation.
- Metrics port (9626): Hockeypuck exports Prometheus-compatible metrics at this port via the
/metricsendpoint.
