Hockeypuck K8S Charm
latest/edge 6 22 Apr 2025
Ubuntu 24.04
2.2/stable 20 28 May 2025
Ubuntu 24.04
2.2/edge 74 04 Apr 2026
Ubuntu 24.04
juju deploy hockeypuck-k8s --channel 2.2/edge
Manage GPG keys
The Hockeypuck charm provides both Juju actions and HTTP APIs for managing OpenPGP keys stored on the keyserver.
Juju actions
The charm provides two main actions for database management: block-keys and lookup-key.
The block-keys action allows you to remove public keys from the keyserver and prevent them from being re-imported via reconciliation. This is useful for managing compromised or spam-related keys.
juju run hockeypuck-k8s/0 block-keys fingerprints=2CF6A6A3B93C138FD51037564415DC328A6C8E00,7EG5A6A3B93C138FD51037568415DC326A6C8F01 comment=R123
This command ensures that the public keys associated with the fingerprints 2CF6A6A3B93C138FD51037564415DC328A6C8E00 and 7EG5A6A3B93C138FD51037568415DC326A6C8F01 are deleted from the keyserver and added to Hockeypuck’s blocklist to prevent the keys from being reconciled again.
The lookup-key action allows you to check if a key associated with the fingerprint is present in the keyserver:
juju run hockeypuck-k8s/0 lookup-key keyword=0x2CF6A6A3B93C138FD51037564415DC328A6C8E00
  • Use 0x prefix only for lookup-key.
  • Do not use 0x prefix when specifying fingerprints in block-keys.
Hockeypuck APIs
The Hockeypuck server also provides a set of SKS-compatible endpoints for interacting with the keyserver over HTTP.
/pks/lookup
Purpose: Retrieve key information by fingerprint, name, or email.
Query Parameters:
  • op: The operation type, e.g., get, vindex, or index.
  • search: The search term (e.g., key ID, fingerprint, email, or name).
  • fingerprint: Optional. If on, returns full fingerprints instead of short key IDs.
Example:
curl "http://$HOCKEYPUCK_ADDRESS/pks/lookup?op=get&search=$FINGERPRINT&fingerprint=on"
/pks/add
Purpose: Add a new public key to the keyserver.
Example:
# store the public key of admin in a file
gpg --armor --export $ADMIN_FINGERPRINT > public_key.asc
curl -X POST -H "Content-Type: application/x-www-form-urlencoded" --data-urlencode "keytext=$(cat public_key.asc)" http://$HOCKEYPUCK_URL/pks/add
/pks/replace
Purpose: Replace an existing public key on the keyserver with a new one.
Example:
curl -X POST -H "Content-Type: application/x-www-form-urlencoded" --data-urlencode "keytext=$(cat request.txt)" --data-urlencode "keysig=$(cat signature.asc)" http://$HOCKEYPUCK_URL/pks/replace
Refer to the Hockeypuck Server Administration for more information on how to generate the signature and the request.
/pks/delete
Purpose: Delete a public key from the keyserver.
Example:
curl -X POST -H "Content-Type: application/x-www-form-urlencoded" --data-urlencode "keytext=$(cat request.txt)" --data-urlencode "keysig=$(cat signature.asc)" http://$HOCKEYPUCK_URL/pks/delete
Help improve this document in the forum (guidelines). Last updated 8 months ago.
