Hockeypuck K8S Charm
| latest/edge | 6 | 22 Apr 2025 | |
| 2.2/stable | 20 | 28 May 2025 | |
| 2.2/edge | 74 | 04 Apr 2026 |
juju deploy hockeypuck-k8s --channel 2.2/edge
Integrate with Canonical Observability Stack
Deploy COS lite
Create a Juju model and deploy the Canonical Observability Stack bundle cos-lite to this model:
juju add-model cos-lite
juju deploy cos-lite --trust
Expose the application relation endpoints
Once all the COS Lite applications are deployed and settled down (you can monitor this by using juju status --watch 2s), expose the relation points for Prometheus, Loki and Grafana:
juju offer prometheus:metrics-endpoint
juju offer loki:logging
juju offer grafana:grafana-dashboard
Validate that the offers have been successfully created by running:
juju find-offers cos-lite
You should see something similar to the output below:
Store URL Access Interfaces
tutorial-controller admin/cos-lite.loki admin loki_push_api:logging
tutorial-controller admin/cos-lite.prometheus admin prometheus_scrape:metrics-endpoint
tutorial-controller admin/cos-lite.grafana admin grafana_dashboard:grafana-dashboard
Integrate Hockeypuck
Switch back to the charm model and integrate your charm with the exposed endpoints:
juju switch <Hockeypuck charm model>
juju integrate hockeypuck-k8s admin/cos-lite.grafana
juju integrate hockeypuck-k8s admin/cos-lite.loki
juju integrate hockeypuck-k8s admin/cos-lite.prometheus
Ensure that Hockeypuck and the COS Lite applications are settled down (you can monitor this by using juju status --watch 2s).
Obtain the Grafana dashboard credentials by running the get-admin-password action:
juju switch cos-lite
juju run grafana/0 get-admin-password
This action returns the URL and the admin password to access the Hockeypuck dashboard. Now, on your host machine, open a web browser, enter the Grafana URL, and use the username “admin” and your Grafana password to log in. Under Home > Dashboards, you should be able to see the Hockeypuck dashboard listed.
This effectively integrates your application with Prometheus, Loki, and Grafana.
