24.04 22.04 20.04
0.44/stable 824 07 Jul 2026
0.44/stable 831 07 Jul 2026
0.44/stable 816 07 Jul 2026
0.44/stable 828 07 Jul 2026
0.44/stable 829 07 Jul 2026
0.44/stable 833 07 Jul 2026
0.44/stable 832 07 Jul 2026
0.44/stable 827 07 Jul 2026
0.44/stable 830 07 Jul 2026
0.44/stable 825 07 Jul 2026
0.44/stable 826 07 Jul 2026
0.44/candidate 893 11 Aug 2026
0.44/candidate 895 11 Aug 2026
0.44/candidate 896 11 Aug 2026
0.44/candidate 897 11 Aug 2026
0.44/candidate 898 11 Aug 2026
0.44/candidate 878 07 Aug 2026
0.44/candidate 880 07 Aug 2026
0.44/candidate 875 07 Aug 2026
0.44/candidate 876 07 Aug 2026
0.44/candidate 872 06 Aug 2026
0.44/candidate 825 07 Jul 2026
0.44/beta 893 11 Aug 2026
0.44/beta 895 11 Aug 2026
0.44/beta 896 11 Aug 2026
0.44/beta 897 11 Aug 2026
0.44/beta 898 11 Aug 2026
0.44/beta 878 07 Aug 2026
0.44/beta 880 07 Aug 2026
0.44/beta 875 07 Aug 2026
0.44/beta 876 07 Aug 2026
0.44/beta 872 06 Aug 2026
0.44/beta 825 07 Jul 2026
0.44/edge 898 10 Aug 2026
0.44/edge 897 10 Aug 2026
0.44/edge 896 10 Aug 2026
0.44/edge 895 10 Aug 2026
0.44/edge 893 10 Aug 2026
0.44/edge 880 06 Aug 2026
0.44/edge 878 06 Aug 2026
0.44/edge 876 06 Aug 2026
0.44/edge 875 06 Aug 2026
0.44/edge 872 05 Aug 2026
0.44/edge 825 07 Jul 2026
dev/edge 992 15 Oct 2026
dev/edge 991 15 Oct 2026
dev/edge 990 15 Oct 2026
dev/edge 989 15 Oct 2026
dev/edge 988 15 Oct 2026
dev/edge 987 15 Oct 2026
dev/edge 986 15 Oct 2026
dev/edge 985 15 Oct 2026
dev/edge 936 27 Aug 2026
dev/edge 929 27 Aug 2026
dev/edge 925 26 Aug 2026
2/stable 851 07 Jul 2026
2/stable 846 07 Jul 2026
2/stable 850 07 Jul 2026
2/stable 849 07 Jul 2026
2/stable 848 07 Jul 2026
2/stable 847 07 Jul 2026
2/candidate 851 18 Jun 2026
2/candidate 846 18 Jun 2026
2/candidate 850 18 Jun 2026
2/candidate 849 18 Jun 2026
2/candidate 848 18 Jun 2026
2/candidate 847 18 Jun 2026
2/beta 851 18 Jun 2026
2/beta 846 18 Jun 2026
2/beta 850 18 Jun 2026
2/beta 849 18 Jun 2026
2/beta 848 18 Jun 2026
2/beta 847 18 Jun 2026
2/edge 851 17 Jun 2026
2/edge 850 17 Jun 2026
2/edge 849 17 Jun 2026
2/edge 848 17 Jun 2026
2/edge 847 17 Jun 2026
2/edge 846 17 Jun 2026
1/stable 606 18 Sep 2025
1/stable 605 18 Sep 2025
1/stable 607 18 Sep 2025
1/stable 603 18 Sep 2025
1/stable 604 18 Sep 2025
1/stable 602 18 Sep 2025
1/candidate 606 09 Sep 2025
1/candidate 605 09 Sep 2025
1/candidate 607 09 Sep 2025
1/candidate 603 09 Sep 2025
1/candidate 604 09 Sep 2025
1/candidate 602 09 Sep 2025
1/beta 606 02 Sep 2025
1/beta 605 02 Sep 2025
1/beta 607 02 Sep 2025
1/beta 603 02 Sep 2025
1/beta 604 02 Sep 2025
1/beta 602 02 Sep 2025
1/edge 607 20 Aug 2025
1/edge 606 20 Aug 2025
1/edge 605 20 Aug 2025
1/edge 604 20 Aug 2025
1/edge 603 20 Aug 2025
1/edge 602 20 Aug 2025
juju deploy grafana-agent --channel 2/edge
All metrics are missing
Inspect the /agent/api/v1/metrics/targets endpoint, for example:
juju ssh grafana-agent/0 curl localhost:12345/agent/api/v1/metrics/targets
Look for entries such as
      "state": "down",
      "last_scrape": "2025-06-09T16:25:49.440292064Z",
      "scrape_duration_ms": 0,
      "scrape_error": "Get \"http://localhost:8081/metrics\": dial tcp 127.0.0.1:8081: connect: connection refused"
Make sure:
  1. Your scrape target is listed.
  2. Address any errors in scrape_error.
Scrape error: connect: connection refused
A scrape will fail with connect: connection refused when:
  • The scrape target is listening on a particular interface (e.g. 127.0.0.1), but the scrape request is coming from somewhere else. The workload should be configured to bind to the correct interface, or to 0.0.0.0 (all interfaces).
"connection reset by peer" and "499 Client Closed Request" errors
Deployment example
Let’s imagine a Grafana Agent charm scrapes an application, and forward their logs to a Prometheus instances in another model.
Signs that something is wrong
In such a deployment, we expect OpenStack metrics to be sent regularly to Prometheus through Grafana Agent, but that doesn’t happen.
If we do some research we may find this kind of error logs in grafana-agent:
Jul 19 12:39:05 scexporter01 grafana-agent.grafana-agent[724]: ts=2024-07-19T12:39:05.965934155Z caller=dedupe.go:112 agent=prometheus instance=605713fb3bd3f34da68dbf90216eef44 component=remote level=warn remote_name=605713-e27a59 url=http://172.16.14.11/cos-prometheus-0/api/v1/write msg="Failed to send batch, retrying" err="Post \"http://172.16.14.11/cos-prometheus-0/api/v1/write\": read tcp 172.16.14.99:39972->172.16.14.11:80: read: connection reset by peer"
The most important part of this log line is: read: connection reset by peer. What this is telling us is that Prometheus is closing the connection grafana-agent is trying to establish.
Since in our deployment Traefik is the ingress for Prometheus, we can confirm this by checking the its logs:
2024-07-22T17:47:10.811Z [traefik] time="2024-07-22T17:47:10Z" level=debug msg="'499 Client Closed Request' caused by: context canceled"
We may think the problem can be somewhere in the connection between Grafana Agent and Prometheus, but in this situation the real problem is in the other end.
Scrape Timeouts
If the application that Grafana Agent is scrapes takes a long time to return its metrics endpoint, in particular a longer time than the default timeout configured in Grafana Agent, we will start to see these types of errors because sends an empty request to Prometheus.
We can verify the response times by running:
$ time curl http://APPLICATION_ADDRESS:PORT/metrics
and we will obtain a bunch of metrics and the response time:
# TYPE ring_member_tokens_to_own gauge
ring_member_tokens_to_own{name="compactor"} 1
ring_member_tokens_to_own{name="scheduler"} 1
curl http://APPLICATION_ADDRESS:PORT/metrics 0,01s user 0,01s system 0% cpu 12,064 total
Note that in this example, the response time is more than 12s and our default global_scrape_timeout in Grafana Agent is 10s.
How to solve this situation
As we could see the problem is the response time of the metrics endpoint Grafana Agent scrapes. We need to figure out the root cause of such delay.
If we are not able to reduce the response times of our metrics endpoint we can increase the global_scrape_timeout in Grafana agent charm by running:
juju config grafana-agent global_scrape_timeout="15s"
Help improve this document in the forum (guidelines). Last updated 1 year, 4 months ago.
