GitHub runner
24.04 22.04 20.04
latest/stable 692 28 Apr 2026
Ubuntu 22.04 Ubuntu 20.04
latest/stable 323 27 Jan 2025
latest/stable 1 09 Feb 2022
latest/beta 692 27 Apr 2026
latest/beta 4 04 Jun 2025
latest/beta 323 17 Jan 2025
latest/edge 693 24 Apr 2026
latest/edge 692 24 Apr 2026
latest/edge 327 06 Feb 2025
latest/edge 4 26 Apr 2022
1/stable 177 05 Jun 2024
1/edge 177 05 Jun 2024
juju deploy github-runner --channel local-lxd/edge
External access
The GitHub Runner Charm itself requires access to the
  • GitHub API (e.g. to register and remove runners).
  • GitHub website (e.g. to download the runner binary or other applications like yq)
  • Ubuntu package repositories (e.g. to install packages)
  • Snap store (e.g. to install LXD or aproxy)
  • Ubuntu Cloud Images (for the image used by a runner)
  • NPM registry (e.g. to download and install specific packages)
In addition, access is required depending on the requirements of the workloads that the runners will be running (as they will be running on the same machine as the charm).
More details on network configuration can be found in the charm architecture documentation.
Help improve this document in the forum (guidelines). Last updated 7 months ago.
