Generic Exporter
Marcus Boden Publisher
26.04 24.04 22.04 20.04
dev/edge 90 30 Sep 2026
Ubuntu 26.04 Ubuntu 24.04 Ubuntu 22.04 Ubuntu 20.04
dev/edge 89 25 Aug 2026
dev/edge 88 25 Aug 2026
dev/edge 87 25 Aug 2026
dev/edge 86 25 Aug 2026
dev/edge 85 25 Aug 2026
dev/edge 84 25 Aug 2026
dev/edge 83 25 Aug 2026
dev/edge 82 20 Aug 2026
dev/edge 81 20 Aug 2026
dev/edge 80 20 Aug 2026
dev/edge 77 19 Aug 2026
dev/edge 76 19 Aug 2026
dev/edge 74 19 Aug 2026
dev/edge 73 19 Aug 2026
dev/edge 63 10 Aug 2026
dev/edge 55 14 Jul 2026
juju deploy generic-exporter --channel dev/edge
Charm lifecycle
This guide outlines how the Generic Exporter operator responds to core Juju events and manages the exporter snap throughout its lifecycle.
Install
On install:
  • Validate that a usable configuration is present:
    • A snap-name is provided, and
    • Either snap-channel or snap-revision is set (but not both).
  • Initialize the snap manager using SnapCache.
  • Install the exporter snap:
    • Using the requested channel or revision.
    • Respecting snap-classic when classic confinement is required.
  • Apply any JSON snap configuration from snap-config using snap.set().
If configuration is missing or invalid (for example, snap-name not set), the charm sets:
BlockedStatus("Missing required configuration fields: snap-name")
and does not proceed with installation.
Config-changed
On config-changed:
  • Re-validate the charm configuration:
    • Reject cases where both snap-channel and snap-revision are set simultaneously.
    • Parse snap-config as JSON; if parsing fails, block with an appropriate message.
  • Reapply snap configuration:
    • Call snap.set() with the parsed configuration.
    • Call snap.unset() if any configuration was unset.
    • On failure, stop the snap and set a Blocked status.
  • Reapply snap-plugs by connecting the requested interfaces.
  • Detect a change in the exporter identity:
    • If the configured exporter changes (for example, snap-name changed), uninstall the previous snap and clean up its alerts directory.
  • Reconcile alert rules:
    • If an alerts resource is present, re-read and rewrite rules to /run/<app-name>-<unit-id>/alerts.yaml.
  • Notify COS integration:
    • Update scrape configuration and alert rules via COSAgentProvider, using config-changed as a refresh event.
Update-status
On update-status, the charm performs a simple health check against the exporter’s HTTP endpoint:
  • Issue a GET request to http://localhost:<port>/<metrics-path>.
    • If the request fails or the endpoint is unreachable, set:
    BlockedStatus("Metrics endpoint not reachable")
  • Ensure that the snap services are active.
  • Check that the charm is related to Opentelemetry Collector
    • If the check fails, the charm sets:
    BlockedStatus("Missing relation: [cos-agent]")
If every check passes, the charm enters Active state. These checks ensure that both the snap and its configuration are functioning as expected.
Remove
On remove:
  • Stop and remove the exporter snap from the unit.
  • Remove the alerts directory and any associated files.
Help improve this document in the forum (guidelines). Last updated 7 months ago.
