Canonical Observability Stack Proxy
26.04 24.04 22.04 20.04
3.0/stable 169 07 Jul 2026
3.0/stable 168 07 Jul 2026
3.0/stable 170 07 Jul 2026
3.0/candidate 169 07 Jul 2026
3.0/candidate 168 07 Jul 2026
3.0/candidate 170 07 Jul 2026
3.0/beta 169 07 Jul 2026
3.0/beta 168 07 Jul 2026
3.0/beta 170 07 Jul 2026
3.0/edge 170 07 Jul 2026
3.0/edge 169 07 Jul 2026
3.0/edge 168 07 Jul 2026
dev/edge 174 12 Aug 2026
Ubuntu 26.04 Ubuntu 24.04 Ubuntu 22.04 Ubuntu 20.04
dev/edge 173 12 Aug 2026
dev/edge 172 12 Aug 2026
dev/edge 171 12 Aug 2026
2/stable 167 12 Nov 2025
2/stable 166 12 Nov 2025
2/candidate 167 08 Oct 2025
2/candidate 166 08 Oct 2025
2/beta 167 31 Mar 2026
2/beta 166 31 Mar 2026
2/edge 167 26 Sep 2025
2/edge 166 26 Sep 2025
1/stable 155 08 Jul 2025
1/stable 156 08 Jul 2025
1/stable 139 26 Jun 2025
1/stable 140 26 Jun 2025
1/candidate 155 26 Jun 2025
1/candidate 156 26 Jun 2025
1/candidate 139 10 Jun 2025
1/candidate 140 10 Jun 2025
1/beta 155 10 Jun 2025
1/beta 156 10 Jun 2025
1/beta 139 13 May 2025
1/beta 140 13 May 2025
1/edge 156 05 Jun 2025
1/edge 155 05 Jun 2025
1/edge 140 13 May 2025
1/edge 139 13 May 2025
juju deploy cos-proxy --channel 1/edge
        labels:
          model: "some-juju-model"
Dashboards
Metrics
Alert rules
For built-in alert rules,
  • Alert exprs are qualified with topology labels. This way, built-in alerts fire only for the particular charm they originated from.
  • Alert labels are enriched with topology labels. This is meant for convenient reading of a rendered alert when presented to an on-caller. The labels would also be visible in the alert’s rendered expr, but alert labels are more convenient to read.
  • Alert rules are NOT enriched with the unit label. This is because we wouldn’t want to replicated all rules per unit. Unit information is included in metric and log labels. Since alert rules are forwarded to prometheus/loki per related app, not unit, having multiple units does not result in prometheus having duplicated alerts per unit. If an alert was qualified with a unit (which one?), we wouldn’t get alerts from any other units.
  • Alert rules descriptions can use a {{ $labels.juju_unit }} macro in the alert’s annotations, which will be replaced with the unit name for better readability.
Logs
Traces
Additional notes
  • In the future, the grafana-agent charm may start exposing metrics and logs generated by its own workload, and those would be enriched by juju topology labels.
  • In the future, the cos-configuration charm may start exposing metrics and logs generated by its own workload, git-sync, and those would be enriched by juju topology labels.
  • In the future (2025) grafana-agent will be replaced by otlp-collector. The general data flow should remain unchanged.
Help improve this document in the forum (guidelines). Last updated 1 year, 11 months ago.
