Content-cache
| latest/stable | 49 | 17 Dec 2024 | |
| latest/edge | 97 | 01 Mar 2026 | |
| latest/edge | 2 | 21 Jun 2021 |
juju deploy content-cache-k8s --channel edge
Redeployment
The content-cache-k8s charm has no underlying state. To redeploy the charm,
you need to proceed with a normal deployment process using the same
configuration options and relations as your original deployment.
