Vault
| 1.19/candidate | 528 | 03 Apr 2026 | |
| 1.19/beta | 528 | 03 Apr 2026 | |
| 1.19/edge | 539 | 14 Apr 2026 | |
| 1.19/edge | 538 | 14 Apr 2026 | |
| 1.18/stable | 507 | 09 Apr 2026 | |
| 1.18/candidate | 507 | 03 Apr 2026 | |
| 1.18/beta | 507 | 03 Apr 2026 | |
| 1.18/edge | 534 | 09 Apr 2026 | |
juju deploy vault-k8s --channel 1.16/candidate
How-to Guides
These how-to guides cover key operations and processes for the Vault charm.
Day-1 operations
Day-1 operations cover the deployment and integration of the Vault charm.
- Unseal a sealed unit
- Configure a Vault for auto-unseal
- Use Vault behind an Ingress
- Use Vault as an intermediate CA
- Use Vault as an ACME Server
- Integrate with COS
Day-2 operations
Day-2 operations cover the management and maintenance of the Vault charm over its lifecycle.
- Scale
- Upgrade Vault
- Create a backup
- Restore a backup
- Recover a Vault Cluster When Raft Quorum is Lost
