Vault
| 1.16/stable | 323 | 20 Jan 2025 | |
| 1.16/candidate | 474 | 18 Nov 2025 | |
| 1.16/beta | 474 | 18 Nov 2025 | |
| 1.16/edge | 482 | 04 Dec 2025 | |
| 1.18/stable | 446 | 26 Sep 2025 | |
| 1.18/candidate | 446 | 26 Sep 2025 | |
| 1.18/beta | 459 | 16 Oct 2025 | |
| 1.18/edge | 492 | Today | |
juju deploy vault-k8s --channel 1.16/edge
Connecting to Vault
