title: Charmhub | Deploy Vault using Charmhub - The Open Operator Collection
description: Deploy the latest version of Vault as a Kubernetes Operator on any cloud.
url: https://charmhub.io/vault-k8s/docs/h-vault-high-availability
# Vault
[Canonical Telco](https://charmhub.io/publisher/telco-charmers "View all packages from Canonical Telco")
* [Canonical Telco](https://charmhub.io/publisher/telco-charmers "View all packages from Canonical Telco")
2.0/stable 565
#### Relevant links
* [Homepage](https://charmhub.io/vault-k8s)
#### Contacts
##### Maintainers
+ [Matrix Channel](https://matrix.to/#/!yAkGlrYcBFYzYRvOlQ:ubuntu.com?via=ubuntu.com&via=matrix.org&via=mozilla.org)
* [Submit a bug](https://github.com/canonical/vault-k8s-operator/issues)
# Starting Vault with Multiple Units
# Connecting to Vault
