Vault
- Canonical Telco
latest/edge | 89 | 31 Jan 2024 | |
latest/edge | 9 | 27 Jan 2023 | |
1.16/stable | 323 | 20 Jan 2025 | |
1.16/candidate | 323 | 20 Jan 2025 | |
1.16/beta | 355 | 25 Mar 2025 | |
1.16/edge | 355 | 25 Mar 2025 | |
1.17/stable | 354 | 11 Apr 2025 | |
1.17/candidate | 354 | 11 Apr 2025 | |
1.17/beta | 354 | 25 Mar 2025 | |
1.17/edge | 364 | 23 Apr 2025 | |
1.15/stable | 248 | 24 Jul 2024 | |
1.15/candidate | 248 | 24 Jul 2024 | |
1.15/beta | 248 | 24 Jul 2024 | |
1.15/edge | 248 | 10 Jul 2024 |
juju deploy vault-k8s --channel 1.16/edge
Use Vault as an intermediate CA
In this how-to guide, we will configure Vault to act as an intermediate Certificate Authority (CA) using Vault’s PKI secrets engine. Here self-signed-certificates will be the parent CA and tls-certificates-requirer will be the charm requesting a certificate to Vault.
The certificates issued by Vault will have a validity period that is half of its intermediate CA’s, which is determined by the root provider’s configuration, in this case, the self-signed certificates.
- Configure Vault’s common name
Vault PKI will only allow issuing certificates for the subdomains of the common_name configured here, it will reject any requests using differnt domains in their subject.
juju config vault common_name=mydomain.com
- Deploy the parent CA
juju deploy self-signed-certificates --channel 1/stable
- Integrate Vault with its parent CA
juju integrate vault:tls-certificates-pki self-signed-certificates
- Deploy
The common name must be a subdomain of the Vault common name
juju deploy tls-certificates-requirer --config common_name=demo.mydomain.com --config sans_dns=demo.mydomain.com
- Integrate TLS Certificates Requirer with Vault
juju integrate tls-certificates-requirer vault:vault-pki
- Retrieve the certificate
juju run tls-certificates-requirer/leader get-certificate
