title: Charmhub | Deploy Vault using Charmhub - The Open Operator Collection
description: Deploy the latest version of Vault as a Kubernetes Operator on any cloud.
url: https://charmhub.io/vault-k8s/docs/h-upgrade-vault
# Vault
[Canonical Telco](https://charmhub.io/publisher/telco-charmers "View all packages from Canonical Telco")
* [Canonical Telco](https://charmhub.io/publisher/telco-charmers "View all packages from Canonical Telco")
2.0/stable 590
#### Relevant links
* [Homepage](https://canonical-vault-charms.readthedocs-hosted.com/)
#### Contacts
##### Maintainers
+ [Matrix Channel](https://matrix.to/#/!yAkGlrYcBFYzYRvOlQ:ubuntu.com?via=ubuntu.com&via=matrix.org&via=mozilla.org)
* [Submit a bug](https://github.com/canonical/vault-k8s-operator/issues)
# Upgrade Vault
## [Pre-requisites](https://charmhub.io/vault-k8s/docs/h-upgrade-vault#p-33309-pre-requisites)
* Vault >= 1.15 is deployed
* In the case of upgrading `vault-k8s`, it is recommended to have at least 5 units deployed and active to ensure minimal to no downtime.
## [Upgrade Procedure](https://charmhub.io/vault-k8s/docs/h-upgrade-vault#p-33309-upgrade-procedure)
* Create a backup of your Vault data following [this guide](https://charmhub.io/vault-k8s/docs/h-create-a-backup-with-vault-k8s) (in case anything goes wrong during the upgrade).
* run `juju refresh vault --channel=$VAULT_HIGHER_VERSION` where VAULT\_HIGHER\_VERSION is any version higher than the one you have currently deployed.
