title: Charmhub | Deploy Vault using Charmhub - The Open Operator Collection
description: Deploy the latest version of Vault as a Kubernetes Operator on any cloud.
url: https://charmhub.io/vault-k8s/docs/h-security-in-charmed-vault
# Vault
[Canonical Telco](https://charmhub.io/publisher/telco-charmers "View all packages from Canonical Telco")
* [Canonical Telco](https://charmhub.io/publisher/telco-charmers "View all packages from Canonical Telco")
2.0/stable 565
#### Relevant links
* [Homepage](https://charmhub.io/vault-k8s)
#### Contacts
##### Maintainers
+ [Matrix Channel](https://matrix.to/#/!yAkGlrYcBFYzYRvOlQ:ubuntu.com?via=ubuntu.com&via=matrix.org&via=mozilla.org)
* [Submit a bug](https://github.com/canonical/vault-k8s-operator/issues)
# Security in Charmed Vault
## [Charmed Vault Built-in Security Features](https://charmhub.io/vault-k8s/docs/h-security-in-charmed-vault#p-36923-charmed-vault-built-in-security-features)
* Built using a bare-bones, distroless [Vault ROCK](https://github.com/canonical/vault-rock) image which is regularly built and scanned for vulnerabilities
* [TLS](https://charmhub.io/vault-k8s/docs/h-tls) 1.3 encrypted communication amongst the Vault units, and any communication channels between clients the Vault server
* [Policies](https://charmhub.io/vault-k8s/docs/h-vault-charm-policies) that restrict the access of the Charm to only the essential operations
* Policies that restrict the access of credentials generated by the charm to the minimum set of operations needed.
* [Canonical Observability Stack integration](https://charmhub.io/vault-k8s/docs/h-integrate-with-cos)
* Audit logging
* Short-lived token TTLs
## [Some Best Practices to be Aware of](https://charmhub.io/vault-k8s/docs/h-security-in-charmed-vault#p-36923-some-best-practices-to-be-aware-of)
### [Authorize the Charm with a short lived token](https://charmhub.io/vault-k8s/docs/h-security-in-charmed-vault#p-36923-authorize-the-charm-with-a-short-lived-token)
vault token create -ttl=5m
### [Handling Unseal Keys](https://charmhub.io/vault-k8s/docs/h-security-in-charmed-vault#p-36923-handling-unseal-keys)
We recommended you follow [HashiCorp’s guidance on unseal keys](https://developer.hashicorp.com/vault/docs/configuration/seal/seal-best-practices#operator-overhead). Specifically, ensure that the unseal keys are not a single source of failure or loss. Due to the overhead of unsealing, you may wish to use auto-unseal in enterprise environments.
### [When to use Auto-unseal](https://charmhub.io/vault-k8s/docs/h-security-in-charmed-vault#p-36923-when-to-use-auto-unseal)
1. Is fully trusted to handle the decryption keys of your Vault
2. Has minimal downtime
3. Has processes in place to ensure that new nodes can be unsealed promptly when necessary
