title: Charmhub | Deploy Vault using Charmhub - The Open Operator Collection
description: Deploy the latest version of Vault as a Kubernetes Operator on any cloud.
url: https://charmhub.io/vault-k8s/docs/h-scale
# Vault
[Canonical Telco](https://charmhub.io/publisher/telco-charmers "View all packages from Canonical Telco")
* [Canonical Telco](https://charmhub.io/publisher/telco-charmers "View all packages from Canonical Telco")
2.0/stable 565
#### Relevant links
* [Homepage](https://charmhub.io/vault-k8s)
#### Contacts
##### Maintainers
+ [Matrix Channel](https://matrix.to/#/!yAkGlrYcBFYzYRvOlQ:ubuntu.com?via=ubuntu.com&via=matrix.org&via=mozilla.org)
* [Submit a bug](https://github.com/canonical/vault-k8s-operator/issues)
# Scale
The Vault charm uses the [raft](https://developer.hashicorp.com/vault/docs/configuration/storage/raft) backend to scale. This guide walks you through scaling Vault.
## [Pre-requisites](https://charmhub.io/vault-k8s/docs/h-scale#p-31159-pre-requisites)
* Vault is initialised and unsealed
* The Vault charm is authorised
## [1. Validate that Vault is an active state](https://charmhub.io/vault-k8s/docs/h-scale#p-31159-h-1-validate-that-vault-is-an-active-state)
Run `juju status`:
Model  Controller          Cloud/Region        Version  SLA          Timestamp
demo   microk8s-localhost  microk8s/localhost  3.4.0    unsupported  12:52:32-04:00
App    Version  Status   Scale  Charm      Channel    Rev  Address         Exposed  Message
vault           waiting      1  vault-k8s  1.15/beta  198  10.152.183.208  no       installing agent
Unit      Workload  Agent  Address      Ports  Message
vault/0*  active    idle   10.1.182.38
## [2. Scale Vault to 3 units](https://charmhub.io/vault-k8s/docs/h-scale#p-31159-h-2-scale-vault-to-3-units)
Add 2 more units:
juju add-unit vault -n 2
The new units will be sealed:
demo   microk8s-localhost  microk8s/localhost  3.4.0    unsupported  12:54:51-04:00
vault           waiting      3  vault-k8s  1.15/beta  198  10.152.183.208  no       installing agent
vault/1   blocked   idle   10.1.182.51         Please unseal Vault
vault/2   blocked   idle   10.1.182.34         Please unseal Vault
Set the `VAULT_ADDR` variable to the `vault/1` unit:
export VAULT_ADDR=https://$(juju status vault/1 --format=yaml |  yq '.applications.vault.units.vault/1.address'):8200; echo $VAULT_ADDR
Set the `VAULT_SKIP_VERIFY` to true:
export VAULT_SKIP_VERIFY=true
Unseal the the `vault/1` unit using the same unseal keys as received during the initialization of the Vault leader:
vault operator unseal EJoB62t286mjUpSQYZg3mOla3lz/bbElVL5OLnj+rpE=
And complete the same operations for the `vault/2` unit:
export VAULT_ADDR=https://$(juju status vault/2 --format=yaml |  yq '.applications.vault.units.vault/2.address'):8200; echo $VAULT_ADDR
## [3. Validate that all units are part of the cluster](https://charmhub.io/vault-k8s/docs/h-scale#p-31159-h-3-validate-that-all-units-are-part-of-the-cluster)
All units should go to the `Active/Idle` Juju status:
$ juju status
demo   microk8s-localhost  microk8s/localhost  3.4.0    unsupported  12:57:52-04:00
vault           active      3  vault-k8s  1.15/beta  198  10.152.183.208  no
vault/1   active    idle   10.1.182.51
vault/2   active    idle   10.1.182.34
And they should all be part of the raft cluster:
$ vault operator raft list-peers
Node            Address                                                State       Voter
demo-vault/0    vault-0.vault-endpoints.demo.svc.cluster.local:8201    leader      true
demo-vault/1    vault-1.vault-endpoints.demo.svc.cluster.local:8201    follower    true
demo-vault/2    vault-2.vault-endpoints.demo.svc.cluster.local:8201    follower    true
