title: Charmhub | Deploy Vault using Charmhub - The Open Operator Collection
description: Deploy the latest version of Vault as a Kubernetes Operator on any cloud.
url: https://charmhub.io/vault-k8s/docs/h-restore-a-backup-with-vault-k8s
# Vault
[Canonical Telco](https://charmhub.io/publisher/telco-charmers "View all packages from Canonical Telco")
* [Canonical Telco](https://charmhub.io/publisher/telco-charmers "View all packages from Canonical Telco")
2.0/stable 565
#### Relevant links
* [Homepage](https://charmhub.io/vault-k8s)
#### Contacts
##### Maintainers
+ [Matrix Channel](https://matrix.to/#/!yAkGlrYcBFYzYRvOlQ:ubuntu.com?via=ubuntu.com&via=matrix.org&via=mozilla.org)
* [Submit a bug](https://github.com/canonical/vault-k8s-operator/issues)
# Restore a backup
## [Pre-requisites](https://charmhub.io/vault-k8s/docs/h-restore-a-backup-with-vault-k8s#p-29493-pre-requisites)
To restore a Vault Backup, ensure you:
* Have a Vault cluster deployed.
* Your Vault deployment is in *active idle* state.
* Have access to S3 storage where your backup is saved.
* Have [configured the settings for S3 storage](https://charmhub.io/vault-k8s/docs/h-s3-storage-for-vault-backup-and-restore).
* Have access to the unseal keys and root-token used by the Vault cluster at the time of creating the backup.
Once the prerequisites are in place you can run the `restore-backup` action on the leader unit to restore the specified backup, providing the following parameters to the action:
* backup-id: Identifier of the backup you are attempting to restore, as saved on the S3 storage.
`juju run vault/leader restore-backup backup-id=<backup-id>`
The restored Vault will be unsealed and it will require to be [unsealed](https://charmhub.io/vault-k8s/docs/h-unseal) an authorised using root token and unseal key that were in use at the time of creating the backup.
## [List backups](https://charmhub.io/vault-k8s/docs/h-restore-a-backup-with-vault-k8s#p-29493-list-backups)
You can get a list of the identifiers of all the backups that are stored on the configured S3 storage using the `list-backups` action:
`juju run vault/leader list-backups`
## [Restore Backups created in different environments](https://charmhub.io/vault-k8s/docs/h-restore-a-backup-with-vault-k8s#p-29493-restore-backups-created-in-different-environments)
To restore a snapshot that wasn’t created using the Vault charm’s `create-backup` action, you’ll need to manually upload it to the S3 storage accessible by the Vault charm where the `restore-backup` action will run.
1. [Configure the settings for S3 storage](https://charmhub.io/vault-k8s/docs/h-s3-storage-for-vault-backup-and-restore).
2. Connect to your S3 storage
3. Use the same bucket configured in step 1 to store the snapshot
4. Use the ID of the stored snapshot to run the restore backup action
