Vault
| 2.0/beta | 565 | 23 Jun 2026 | |
| 2.0/edge | 576 | Today | |
| 2.0/edge | 575 | Today | |
| 2.0/edge | 572 | 06 Jul 2026 | |
| 1.19/stable | 528 | 21 Apr 2026 | |
| 1.19/candidate | 528 | 03 Apr 2026 | |
| 1.19/beta | 528 | 03 Apr 2026 | |
| 1.19/edge | 544 | 04 May 2026 | |
| 1.19/edge | 543 | 04 May 2026 | |
| 1.18/stable | 534 | 01 Jul 2026 | |
| 1.18/candidate | 534 | 01 Jul 2026 | |
| 1.18/beta | 534 | 01 Jul 2026 | |
| 1.18/edge | 534 | 09 Apr 2026 | |
juju deploy vault-k8s --channel 1.15/beta
- A Charmed Vault instance you wish to use as the unsealer. Deployed, initialized, unsealed, and authorized. See Tutorial: Getting started with Vault-K8s or Getting Started: Vault (Machine) if you’re not there yet.
- A second Charmed Vault instance you wish to use as the autounsealed Vault. This instance may already be initialized, unsealed, and authorized, or you may initialize it as part of this process.
export VAULT_ADDR="..."
export VAULT_TOKEN="..."
vault operator init
$ vault token create -ttl=10m
Key Value
token hvs.mmMXCLNZ2X7OcqCM38WYDnoX
token_accessor eXzWoD1ajA5YtNgfopj1DP1r
token_duration 10m
token_renewable true
token_policies ["root"]
identity_policies []
policies ["root"]
secret:cqgj49fmp25c7796r0pg
