title: Charmhub | Deploy Vault using Charmhub - The Open Operator Collection
description: Deploy the latest version of Vault as a Kubernetes Operator on any cloud.
url: https://charmhub.io/vault-k8s/docs/h-enable-vault-autounseal
# Vault
[Canonical Telco](https://charmhub.io/publisher/telco-charmers "View all packages from Canonical Telco")
* [Canonical Telco](https://charmhub.io/publisher/telco-charmers "View all packages from Canonical Telco")
2.0/stable 590
#### Relevant links
* [Homepage](https://canonical-vault-charms.readthedocs-hosted.com/)
#### Contacts
##### Maintainers
+ [Matrix Channel](https://matrix.to/#/!yAkGlrYcBFYzYRvOlQ:ubuntu.com?via=ubuntu.com&via=matrix.org&via=mozilla.org)
* [Submit a bug](https://github.com/canonical/vault-k8s-operator/issues)
# Configure a Vault for auto-unseal
**WARNING: There is currently no way to remove the auto-unseal configuration once it has been set on Charmed Vault. Removing the integration may put Charmed Vault in a bad state which requires manual intervention.**
## [Prerequisites](https://charmhub.io/vault-k8s/docs/h-enable-vault-autounseal#p-32007-prerequisites)
1. A Charmed Vault instance you wish to use as the *unsealer*. Deployed, initialized, unsealed, and authorized. See [Tutorial: Getting started with Vault-K8s](https://charmhub.io/vault-k8s/docs/h-getting-started) or [Getting Started: Vault (Machine)](https://discourse.charmhub.io/t/getting-started-vault-machine/13042) if you’re not there yet.
2. A second Charmed Vault instance you wish to use as the *autounsealed* Vault. This instance may already be initialized, unsealed, and authorized, or you may initialize it as part of this process.
## [1. Integrate the Vault instances](https://charmhub.io/vault-k8s/docs/h-enable-vault-autounseal#p-32007-h-1-integrate-the-vault-instances)
Integrate the *autounsealed* Vault instance with the *unsealer* Vault instance.
## [2. Configure the Vault CLI to interact with the *autounsealed* Vault.](https://charmhub.io/vault-k8s/docs/h-enable-vault-autounseal#p-32007-h-2-configure-the-vault-cli-to-interact-with-the-autounsealed-vault)
export VAULT_ADDR="..."
export VAULT_TOKEN="..."
Now, either follow 2a for an initialized *autounsealed* Vault instance, or 2b for an uninitialized *autounsealed* Vault instance.
### [2a. Migrate the *autounsealed* Vault instance to auto-unseal](https://charmhub.io/vault-k8s/docs/h-enable-vault-autounseal#p-32007-h-2a-migrate-the-autounsealed-vault-instance-to-auto-unseal)
In this step, the Vault instance being migrated needs to be unsealed with the existing *manual unseal keys*, and migrate its data to auto-unseal. To do this, unseal the Vault instance with the `-migrate` flag.
### [2b. If not already initialized, initialize and authorize the *autounsealed* Vault instance](https://charmhub.io/vault-k8s/docs/h-enable-vault-autounseal#p-32007-h-2b-if-not-already-initialized-initialize-and-authorize-the-autounsealed-vault-instance)
Configure your CLI to interact with the *autounsealed* Vault instance. See the getting started guide for more information on how to do this. In short, you will need to set the `VAULT_ADDR` environment variable to the address of the *autounsealed* Vault instance, and retrieve and set the appropriate CA certificate.
vault operator init
$ vault token create -ttl=10m
Key                  Value
token                hvs.mmMXCLNZ2X7OcqCM38WYDnoX
token_accessor       eXzWoD1ajA5YtNgfopj1DP1r
token_duration       10m
token_renewable      true
token_policies       ["root"]
identity_policies    []
policies             ["root"]
secret:cqgj49fmp25c7796r0pg
Grant the secret to the *autounsealed* vault, and provide the ID of the secret to the `authorize-charm` action.
