title: Charmhub | sunsetting `tempo-k8s`, welcome Charmed Tempo HA
description: The tempo-k8s charm, a monolithic, development product which we worked
  on for about one year to have a platform to test distributed tracing, is being...
url: https://charmhub.io/topics/charmed-tempo-ha/migration-guide
# sunsetting `tempo-k8s`, welcome Charmed Tempo HA
[The `tempo-k8s` charm](https://charmhub.io/tempo-k8s), a monolithic, development product which we worked on for about one year to have a platform to test distributed tracing, is being deprecated in favour of its HA version.
The replacement is called [Charmed Tempo HA](https://charmhub.io/topics/charmed-tempo-ha) and is a resilient, scalable and highly available solution for deploying and operating Tempo on kubernetes.
# Migration guide
The Charmed Tempo HA solution consists of two charms, the “coordinator” and one or more “workers”. The workers are the units that actually run the Tempo backend processes; the coordinator is responsible for reverse-proxying, distributing the configuration among the workers, and load-balancing.
> Also see: [COS-Lite docs - Managing deployments of COS-Lite HA addons](https://charmhub.io/topics/charmed-tempo-ha/COS-Lite HA addons)
API-wise, the coordinator charm plays the role `tempo-k8s` used to play. It supports the same interfaces and relation endpoints, therefore you should be able to swap `tempo-k8s` with the coordinator app and obtain a functionally equivalent deployment.
So once you have deployed Charmed Tempo HA (see [this tutorial](https://charmhub.io/topics/charmed-tempo-ha/Deploy charmed tempo HA + COS-Lite) for instructions), you can destroy your `tempo-k8s` deployment and plug the coordinator in its place by relating to all tracing protocol requirers and traefik, certificates providers, COS Lite, and any other integration `tempo-k8s` used to have.
## [Data migration](https://charmhub.io/topics/charmed-tempo-ha/migration-guide#p-34147-data-migration)
`tempo-k8s` used an in-memory storage, whereas Charmed Tempo HA uses s3 buckets to store trace data.
It’s currently impossible to migrate data between the two, so we advise, if you are migrating a live deployment, to deploy both stacks alongside one another and wipe the old one after a sufficient amount of time has passed, to allow old history to flush itself away to irrelevance and recent history to pool up in the more robust HA solution.
# Charm library migration
If you own a charm that integrates with `tempo-k8s` over tracing, you will need to swap the `tracing` and `charm_tracing` charm libs with their new versions who live under the `tempo-coordinator-k8s` namespace.
Unless you are doing something exceptionally hacky with the libraries, you should be able to follow this simple script for replacing `lib.charms.tempo_k8s` with `lib.charms.tempo_coordinator_k8s`
# in your charm repo:
# remove the old charm libs
rm -rf ./lib/charms/tempo_k8s
# fetch the new charm libs
charmcraft fetch-lib charms.tempo_coordinator_k8s.v0.charm_tracing
charmcraft fetch-lib charms.tempo_coordinator_k8s.v0.tracing
# replace the import paths with the new ones
find ./src ./tests \( -type d -name .git -prune \) -o -type f -print0 | xargs -0 sed -i -e 's/tempo_k8s.v1/tempo_coordinator_k8s.v0/g' -e 's/tempo_k8s.v2/tempo_coordinator_k8s.v0/g'
The APIs and public symbols have not changed, so this somewhat crude strategy should suffice for most use cases.
For examples of migrations carried out in our team, see:
* [PR in `loki-k8s-operator`](https://github.com/canonical/loki-k8s-operator/pull/462)
* [PR in `alertmanager-k8s-operator`](https://github.com/canonical/alertmanager-k8s-operator/pull/296)
However, if you haven’t done so already, this is a perfect opportunity to start using the `charm_tracing_config` helper function from the `tracing` library to help you configure charm tracing in the right way!
## [Using the `charm_tracing_config` helper](https://charmhub.io/topics/charmed-tempo-ha/migration-guide#p-34147-using-the-charm_tracing_config-helper)
Old code:
from charms.tempo_coordinator_k8s.v0.charm_tracing import trace_charm
from charms.tempo_coordinator_k8s.v0.tracing import TracingEndpointRequirer
@trace_charm("tracing_endpoint",  "tracing_cert")
class MyCharm(CharmBase):
    def __init__(...):
        self.tracing = TracingEndpointRequirer(self)
    def tracing_endpoint(self):
        # actually some more complex logic here, see below.
        return self.tracing.get_endpoint("otlp_http")
    def tracing_cert(self):
        return "/path/to/cert.crt"
In earlier revisions of the tracing libraries, your charm would be responsible for passing to the charm tracing machinery the right combination of endpoint and cert depending on the situation:
* endpoint is https
  + cert is not on disk: tracing disabled (or flushing would fail with TLS errors)
  + cert is on disk: tracing enabled
* endpoint is http: tracing enabled regardless of cert
In order to disable charm tracing, the caller would be responsible for returning None from the tracing endpoint passed to `trace_charm`. This was error-prone.
Consequently we have written a little helper function to give `trace_charm` the right combination of required parameters given a `TracingEndpointRequirer` parameter and the expected location of a tls certificate.
All the charm is responsible for, now, is to ensure that a CA cert is written to that location as soon as it becomes available.
Note that that CA cert must be the same one that Tempo is trusting; otherwise things will not work.
New code:
from charms.tempo_coordinator_k8s.v0.tracing import TracingEndpointRequirer, charm_tracing_config
    def __init__(...):
        self.tracing_endpoint, self.tracing_cert = charm_tracing_config(self.tracing, "/path/to/cert.crt")
*Last updated 2 years ago.*
[Help improve this document in the forum](https://discourse.charmhub.io/t/sunsetting-tempo-k8s-welcome-charmed-tempo-ha/15776).
